A review of methods for leakage management in pipe networks, Urban Water Journal, vol.94, issue.1, pp.25-45, 2010. ,
DOI : 10.1061/(ASCE)0733-9429(2002)128:7(697)
Acoustic Detection of Leaks in Water Pipelines Using Measurements inside Pipe, Journal of Pipeline Systems Engineering and Practice, vol.3, issue.2, pp.47-54, 2012. ,
DOI : 10.1061/(ASCE)PS.1949-1204.0000089
A review of leading-edge leak detection techniques for water distribution systems, 2003. ,
What do we know about pressure:leakage relationships in distribution systems? In: IWA Conference System Approach to leakage control and water distribution system management, 2001. ,
Progress in practical prediction of pressure: leakage, pressure: burst frequency and pressure: consumption relationships, eakage 2005 Conference Proceedings, 2005. ,
Methodology for leakage isolation using pressure sensitivity analysis in water distribution networks, Control Engineering Practice, vol.19, issue.10, pp.1157-1167, 2011. ,
DOI : 10.1016/j.conengprac.2011.06.004
Leakage fault detection in district metered areas of water distribution systems, Journal of Hydroinformatics, vol.14, issue.4, pp.992-1002, 2012. ,
DOI : 10.2166/hydro.2012.109
A Non-Parametric Approach to the Change-Point Problem, Applied Statistics, vol.28, issue.2, pp.126-135, 1979. ,
DOI : 10.2307/2346729
The changepoint model for statistical process control, Journal of Quality Technology, vol.35, issue.4, pp.355-366, 2003. ,
Nonparametric Monitoring of Data Streams for Changes in Location and Scale, Technometrics, vol.53, issue.4, pp.379-389, 2011. ,
DOI : 10.1198/TECH.2011.10069
An ensemble approach to estimate the faulttime instant, Proceedings of the 4th International Conference on Intelligent Controland Information Processing, 2013. ,
On the Asymptotic Efficiency of Certain Nonparametric Two-Sample Tests, The Annals of Mathematical Statistics, vol.25, issue.3, pp.514-522, 1954. ,
DOI : 10.1214/aoms/1177728719
A change-point model for a shift in variance, Journal of Quality Technology, vol.37, issue.1, pp.21-31, 2005. ,
A Multivariate Change-Point Model for Statistical Process Control, Technometrics, vol.48, issue.4, pp.539-549, 2006. ,
DOI : 10.1198/004017006000000291
Two nonparametric control charts for detecting arbitrary distribution changes, Journal of Quality Technology, vol.44, issue.22, pp.102-116, 2012. ,
On a Test of Whether one of Two Random Variables is Stochastically Larger than the Other, The Annals of Mathematical Statistics, vol.18, issue.1, pp.50-60, 1947. ,
DOI : 10.1214/aoms/1177730491
Parametric and nonparametric sequential change detection in R: The cpm package, Journal of Statistical Software ,
