Abstract : Dataset shift is a major challenge in the non-stationary environments wherein the input data distribution may change over time. In a time-series data, detecting the dataset shift point, where the distribution changes its properties is of utmost interest. Dataset shift exists in a broad range of real-world systems. In such systems, there is a need for continuous monitoring of the process behavior and tracking the state of the shift so as to decide about initiating adaptive corrections in a timely manner. This paper presents a novel method to detect the shift-point based on a two-stage structure involving Exponentially Weighted Moving Average (EWMA) chart and Kolmogorov-Smirnov test, which substantially reduces type-I error rate. The algorithm is suitable to be run in real-time. Its performance is evaluated through experiments using synthetic and real-world datasets. Results show effectiveness of the proposed approach in terms of decreased type-I error and tolerable increase in detection time delay.
https://hal.inria.fr/hal-01459655
Contributor : Hal Ifip <>
Submitted on : Tuesday, February 7, 2017 - 1:07:06 PM Last modification on : Thursday, March 5, 2020 - 5:41:31 PM Long-term archiving on: : Monday, May 8, 2017 - 2:12:23 PM
