C-ON bond homolysis of alkoxyamines triggered by paramagnetic copper(II) salts - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Inorganic Chemistry Frontiers Année : 2016
The metal complexation reactions of bis(hexafluoroacetylacetonato)copper(II)(Cu(hfac)(2)) with alkoxyamines (diethyl(2,2-dimethyl-1-(tert-butyl-(1-(pyridine-4-yl)ethoxy)amino)propyl)phosphonate and diethyl (2,2-dimethyl-1-(tert-butyl-(1-(pyridine-2-yl)ethoxy)amino)propyl)phosphonate) were studied. According to X-ray analysis, the molecular and crystal structures of 1:1 complexes depend on the configuration of the free alkoxyamines, that is dimeric (RSSR) and chain-polymeric (RR/SS) structures for para-pyridyl-substituted alkoxyamines, and cyclic unimeric (RS/SR) structure for ortho-pyridyl derivative. The complex (2:1 ratio Cu(hfac)(2)/alkoxyamine) for ortho-pyridyl-substituted alkoxyamine is not resolved. Upon warming, ortho complexes decomposed into free alkoxyamines and only a weak activation was observed. Upon warming, para complexes decomposed into their corresponding unimers, and then, a 21-fold increase in the rate constant of the C-ON bond homolysis was observed compared to the corresponding free alkoxyamines. Tuning of the homolysis rate constant of the C-ON bond via addition of pyridine is also reported.
c6qi00277c.pdf (2.1 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-01460663 , version 1 (28-03-2017)
Paternité - Pas d'utilisation commerciale
Gérard Audran, Elena Bagryanskaya, Irina Bagryanskaya, Paul Brémond, Mariya Edeleva, et al.. C-ON bond homolysis of alkoxyamines triggered by paramagnetic copper(II) salts. Inorganic Chemistry Frontiers, 2016, 3 (11), pp.1464-1472. ⟨10.1039/c6qi00277c⟩. ⟨hal-01460663⟩
173 Consultations
103 Téléchargements
