Generating obstacle conditions for requirements completeness, 2012 34th International Conference on Software Engineering (ICSE), pp.705-715, 2012. ,
DOI : 10.1109/ICSE.2012.6227147
Elaborating Requirements Using Model Checking and Inductive Learning, IEEE Transactions on Software Engineering, vol.39, issue.3, pp.361-383, 2013. ,
DOI : 10.1109/TSE.2012.41
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.650.2109
Foundations of deductive databases and logic programming, pp.89-148, 1988. ,
Top-down induction of first-order logical decision trees, Artificial Intelligence, vol.101, issue.1-2, pp.285-297, 1998. ,
DOI : 10.1016/S0004-3702(98)00034-4
Nonmonotonic Learning in Large Biological Networks, 24th International Conference on Inductive Logic Programming, 2014. ,
DOI : 10.1007/978-3-319-23708-4_3
Constructive negation based on the completed database, Proceedings of the Fifth International Conference and Symposium on Logic Programming, pp.111-125, 1988. ,
Executable specifications for hypothesis-based reasoning with Prolog and Constraint Handling Rules, Journal of Applied Logic, vol.7, issue.3, pp.341-362, 2009. ,
DOI : 10.1016/j.jal.2008.10.004
URL : http://doi.org/10.1016/j.jal.2008.10.004
Nonmonotonic inductive logic programming as abductive search, 2011. ,
Inductive logic programming as abductive search ,
Inductive Logic Programming in Answer Set Programming, ILP 2011, pp.91-97, 2012. ,
DOI : 10.1007/978-3-642-31951-8_12
Formal refinement patterns for goal-driven requirements elaboration, pp.179-190, 1996. ,
DOI : 10.1145/239098.239131
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.56.412
Computing preferred answer sets by meta-interpretation in answer set programming Genome-scale reconstruction of the saccharomyces cerevisiae metabolic network, Gen. Res, vol.3, issue.132, pp.463-498, 2003. ,
clasp: A Conflict-Driven Answer Set Solver, Logic Programming and Nonmonotonic Reasoning, pp.260-265, 2007. ,
DOI : 10.1007/978-3-540-72200-7_23
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.70.3156
Classical negation in logic programs and disjunctive databases, New Generation Computing, vol.38, issue.No. 3, pp.365-386, 1991. ,
DOI : 10.1007/BF03037169
Yeast 5 ??? an expanded reconstruction of the Saccharomyces cerevisiae metabolic network, BMC Systems Biology, vol.6, issue.1, p.55, 2012. ,
DOI : 10.1038/sj.jim.2900584
Abductive Logic Programming, Journal of Logic and Computation, vol.2, issue.6, pp.719-770, 1992. ,
DOI : 10.1093/logcom/2.6.719
The Automation of Science, Science, vol.324, issue.5923, pp.85-89, 2009. ,
DOI : 10.1126/science.1165620
Functional genomic hypothesis generation and experimentation by a robot scientist, Nature, vol.427, issue.6971, pp.247-252, 2004. ,
DOI : 10.1038/nature02236
Biochemistry: The Molecular Basis of Cell Structure and Function, 1979. ,
Inverse entailment and progol, New Generation Computing, vol.12, issue.1, pp.245-286, 1995. ,
DOI : 10.1007/BF03037227
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.31.1630
Theory Completion Using Inverse Entailment, ILP 2000, pp.130-146, 2000. ,
DOI : 10.1007/3-540-44960-4_8
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.43.5787
Inductive Logic Programming: Theory and methods, The Journal of Logic Programming, vol.19, issue.20, pp.629-679, 1994. ,
DOI : 10.1016/0743-1066(94)90035-3
URL : http://doi.org/10.1016/0743-1066(94)90035-3
KEGG: Kyoto Encyclopedia of Genes and Genomes, Nucleic Acids Research, vol.27, issue.1, pp.29-34, 1999. ,
DOI : 10.1093/nar/27.1.29
Hybrid Abductive-Inductive Learning, 2005. ,
DOI : 10.1016/j.jal.2008.10.007
URL : http://doi.org/10.1016/j.jal.2008.10.007
A Nonmonotonic Logical Approach for Modelling and Revising Metabolic Networks, 2009 International Conference on Complex, Intelligent and Software Intensive Systems, pp.825-829, 2009. ,
DOI : 10.1109/CISIS.2009.175
Nonmonotonic abductive inductive learning, Journal of Applied Logic, vol.7, issue.3, pp.329-340, 2009. ,
Automatic Revision of Metabolic Networks through Logical Analysis of Experimental Data, ILP 2009, pp.194-201, 2010. ,
DOI : 10.1007/978-3-642-13840-9_18
Extending and implementing the stable model semantics, Artificial Intelligence, vol.138, issue.1-2, pp.181-234, 2002. ,
DOI : 10.1016/S0004-3702(02)00187-X
URL : http://doi.org/10.1016/s0004-3702(02)00187-x
Modelling Inhibition in Metabolic Pathways Through Abduction and Induction, ILP 2004, pp.305-322 ,
DOI : 10.1007/978-3-540-30109-7_23
jan.ramon@cs.kuleuven.be References 1 First order random forests: learning relational classifiers with complex aggregates, Mach. Learn, vol.64, pp.1-3, 2004. ,
Multi-relational data mining using probabilistic relational models: research summary, Proceedings of the First Workshop in Multi-relational Data Mining, 2001. ,
The WEKA data mining software, ACM SIGKDD Explorations Newsletter, vol.11, issue.1, pp.10-18, 2009. ,
DOI : 10.1145/1656274.1656278
Propositionalisation of Continuous Attributes beyond Simple Aggregation, ILP 2012, pp.32-44, 2013. ,
DOI : 10.1007/978-3-642-38812-5_3
Feature construction using theoryguided sampling and randomised search ,
DOI : 10.1007/978-3-540-85928-4_14
Facets of aggregation approaches to propositionalization, Progress Track at the Thirteenth International Conference on Inductive Logic Programming, 2003. ,
Conception of a GIS-platform to simulate urban densification basedon the analysis of topographic data, Advances in Cartography and GIScience. LNGC, pp.413-430, 0228. ,
Refining aggregate conditions in relational learning Scalable acceleration of inductive logic programs, PKDD 2006 IEEE international conference on field-programmable technology, pp.383-394, 2002. ,
Improving the efficiency of inductive logic programming through the use of query packs, J. Artif. Intell. Res, vol.16, issue.1, pp.135-166, 2002. ,
Learnability and the Vapnik-Chervonenkis dimension, Journal of the ACM, vol.36, issue.4, pp.929-965, 1989. ,
DOI : 10.1145/76359.76371
Toward an architecture for never-ending language learning, Proceedings of the Twenty-Fourth Conference on Artificial Intelligence, 2010. ,
Grammatically biased learning: Learning logic programs using an explicit antecedent description language, Artificial Intelligence, vol.68, issue.2, pp.303-366, 1994. ,
DOI : 10.1016/0004-3702(94)90070-1
Declarative modeling for machine learning and data mining Web server workload characterization: the search for invariants, ALT 2012, pp.126-137, 1996. ,
Statistical properties of probabilistic context-free grammars, Comput. Linguist, vol.25, issue.1, pp.131-160, 1999. ,
Problog: a probabilistic prolog and its application in link discovery, IJCAI, vol.7, pp.2462-2467, 2007. ,
On the interaction between plan recognition and intelligent interfaces, User Modelling and User-Adapted Interaction, vol.14, issue.4, pp.1-2, 1992. ,
DOI : 10.1007/BF01101860
The lumiere project: Bayesian user modeling for inferring the goals and needs of software users, Proceedings of the Fourteenth Conference on Uncertainty in Artificial Intelligence, pp.256-265, 1998. ,
Advanced dynamic programming in semiring and hypergraph frameworks, In: COLING, 2008. ,
Computation of the probability of initial substring generation by stochastic context-free grammars, Comput. Linguist, vol.17, issue.3, pp.315-323, 1991. ,
Using Plan Recognition in Human-Computer Collaboration, UM99 User Modeling. CISM International Centre for Mechanical Sciences -Courses and Lectures, pp.23-32, 1999. ,
DOI : 10.1007/978-3-7091-2490-1_3
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.2.9528
Computation of infix probabilities for probabilistic context-free grammars, Proceedings of the Conference on Empirical Methods in Natural Language Processing, pp.1213-1221, 2011. ,
A statistical learning method for logic programs with distribution semantics, Proceedings of Internationall Conference on Logic Programming, p.1995, 1995. ,
Parameter learning of logic programs for symbolic-statistical modeling, J. Artif. Intell. Res, vol.15, pp.391-454, 2001. ,
New Advances in Logic-Based Probabilistic Modeling by PRISM, Probabilistic Inductive Logic Programming, pp.118-155 ,
DOI : 10.1007/978-3-540-78652-8_5
Abstract, Theory and Practice of Logic Programming, vol.15, issue.06, pp.1-29, 2013. ,
DOI : 10.1145/131295.131299
URL : https://hal.archives-ouvertes.fr/hal-00258389
An efficient probabilistic context-free parsing algorithm that computes prefix probabilities, Comput. Linguist, vol.21, issue.2, pp.165-201, 1995. ,
Probabilistic Languages: A Review and Some Open Questions, Theory of Declarative Knowledge. Foundations of Deductive Databases and Logic Programming, pp.361-379, 1980. ,
DOI : 10.1145/356827.356829
The connectionist inductive learning and logic programming system, Applied Intelligence, vol.11, issue.1, pp.59-77, 1999. ,
DOI : 10.1023/A:1008328630915
A SAT-Based Algorithm for Finding Attractors in Synchronous Boolean Networks, IEEE/ACM Transactions on Computational Biology and Bioinformatics, vol.8, issue.5, pp.1393-1399, 2011. ,
DOI : 10.1109/TCBB.2010.20
Symbolic knowledge extraction from trained neural networks: A sound approach, Artificial Intelligence, vol.125, issue.1-2, pp.155-207, 2001. ,
DOI : 10.1016/S0004-3702(00)00077-1
Answer Set Solving in Practice, Synthesis Lectures on Artificial Intelligence and Machine Learning, vol.6, issue.3, 2012. ,
DOI : 10.2200/S00457ED1V01Y201211AIM019
Logic programming for boolean networks, Proceedings of the Twenty- Second International Joint Conference on Artificial Intelligence-Volume, pp.924-930, 2011. ,
DNF Hypotheses in Explanatory Induction, ILP 2011, pp.173-188, 2012. ,
DOI : 10.1007/978-3-642-31951-8_18
Learning from interpretation transition, Machine Learning, vol.23, issue.4, pp.51-79, 2014. ,
DOI : 10.1007/s10994-013-5353-8
Oscillating Behavior of Logic Programs, Correct Reasoning, pp.345-362, 2012. ,
DOI : 10.1016/0743-1066(94)00023-Y
An incremental method for generating prime implicants/implicates, Journal of Symbolic Computation, vol.9, issue.2, pp.185-206, 1990. ,
DOI : 10.1016/S0747-7171(08)80029-6
URL : http://doi.org/10.1016/s0747-7171(08)80029-6
A theory and methodology of inductive learning, Artificial Intelligence, vol.20, issue.2, pp.111-161, 1983. ,
DOI : 10.1016/0004-3702(83)90016-4
Generalization as search, Artificial Intelligence, vol.18, issue.2, pp.203-226, 1982. ,
DOI : 10.1016/0004-3702(82)90040-6
ILP turns 20, Machine Learning, vol.14, issue.1???3, pp.3-23, 2012. ,
DOI : 10.1007/s10994-011-5259-2
URL : http://dx.doi.org/10.1007/s10994-011-5259-2
A note on inductive generalization, Mach. Intel, vol.5, issue.1, pp.153-163, 1970. ,
A BDD-Based Algorithm for Learning from Interpretation Transition, ILP 2013, pp.47-63, 2014. ,
DOI : 10.1007/978-3-662-44923-3_4
Generalization of Consensus Theory and Application to the Minimization of Boolean Functions, IEEE Transactions on Electronic Computers, vol.16, issue.4, pp.446-456, 1967. ,
DOI : 10.1109/PGEC.1967.264648
The Semantics of Predicate Logic as a Programming Language, Journal of the ACM, vol.23, issue.4, pp.733-742, 1976. ,
DOI : 10.1145/321978.321991
A Markov logic approach to biomolecular event extraction, Proceedings of the Workshop on Current Trends in Biomedical Natural Language Processing: Shared Task, pp.41-49, 2009. ,
DOI : 10.3115/1572340.1572347
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.164.3311
Joint inference for knowledge extraction from biomedical literature, pp.813-821, 2010. ,
Jointly identifying temporal relations with Markov Logic, Proceedings of the Joint Conference of the 47th Annual Meeting of the ACL and the 4th International Joint Conference on Natural Language Processing of the AFNLP: Volume 1, ACL-IJCNLP '09, pp.405-413, 2009. ,
DOI : 10.3115/1687878.1687936
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.147.8919
Unsupervised semantic parsing, Proceedings of the 2009 Conference on Empirical Methods in Natural Language Processing Volume 1, EMNLP '09, pp.1-10, 2009. ,
DOI : 10.3115/1699510.1699512
URL : http://ai.cs.washington.edu/www/media/papers/poon09.pdf
View learning for statistical relational learning: with an application to mammography, IJCAI, DTIC Document, pp.677-683, 2005. ,
Change of representation for statistical relational learning, pp.2719-2726, 2007. ,
An Integrated Approach to Learning Bayesian Networks of Rules, ECML 2005, pp.84-95, 2005. ,
DOI : 10.1007/11564096_13
Gradient-based boosting for statistical relational learning: The relational dependency network case, Machine Learning, vol.64, issue.1, pp.25-56, 2012. ,
DOI : 10.1007/s10994-011-5244-9
Statistical relational learning to predict primary myocardial infarction from electronic health records, 2012. ,
Early prediction of coronary artery calcification levels using machine learning, 2013. ,
Relational learning helps in three-way classification of Alzheimer patients from structural magnetic resonance images of the brain, International Journal of Machine Learning and Cybernetics, vol.3, issue.4, pp.659-669, 2013. ,
DOI : 10.1007/s13042-013-0161-9
A relational distance-based framework for hierarchical image understanding, Proceedings of the 1st International Conference on Pattern Recognition Applications and Methods, pp.206-218, 2012. ,
A relational kernel-based approach to scene classification, 2013 IEEE Workshop on Applications of Computer Vision (WACV), pp.133-139, 2013. ,
DOI : 10.1109/WACV.2013.6475010
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.298.4200
Model combination for event extraction in bionlp, Proceedings of the BioNLP Shared Task 2011 Workshop, pp.51-55, 2011. ,
Machine Learning for Sequential Data: A Review, SPR 2002 and SSPR 2002, pp.15-30, 2002. ,
DOI : 10.1007/3-540-70659-3_2
Unconstrained on-line handwriting recognition with recurrent neural networks, Advances in Neural Information Processing Systems, pp.577-584, 2007. ,
HMM-based on-line recognition of handwritten whiteboard notes, Tenth International Workshop on Frontiers in Handwriting Recognition, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00108307
Segmentation Based Online Word Recognition: A Conditional Random Field Driven Beam Search Strategy, 2013 12th International Conference on Document Analysis and Recognition, pp.852-856, 2013. ,
DOI : 10.1109/ICDAR.2013.174
Method and apparatus for recognizing cursive writing from sequential input information, p.527, 1994. ,
On-line handwritten alphanumeric character recognition using dominant points in strokes, Pattern Recogn, vol.30, issue.1, pp.31-44, 1997. ,
An evaluation of motor models of handwriting, IEEE Transactions on Systems, Man, and Cybernetics, vol.19, issue.5, pp.1060-1072, 1989. ,
DOI : 10.1109/21.44021
A fuzzy-syntactic approach to allograph modeling for cursive script recognition, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.17, issue.7, pp.702-712, 1995. ,
DOI : 10.1109/34.391412
Fuzzy handwriting description language:, Pattern Recognition, vol.33, issue.1, pp.119-131, 2000. ,
DOI : 10.1016/S0031-3203(99)00034-5
Recognition of hand printed Latin characters using machine learning, Proceedings of 3rd International Conference on Document Analysis and Recognition, pp.1098-1102, 1995. ,
DOI : 10.1109/ICDAR.1995.602102
LEARNING TO RECOGNIZE HAND-PRINTED CHINESE CHARACTERS USING INDUCTIVE LOGIC PROGRAMMING, International Journal of Pattern Recognition and Artificial Intelligence, vol.10, issue.07, pp.829-847, 1996. ,
DOI : 10.1142/S0218001496000487
NPen/sup ++/: a writer independent, large vocabulary on-line cursive handwriting recognition system, Proceedings of 3rd International Conference on Document Analysis and Recognition, pp.403-408, 1995. ,
DOI : 10.1109/ICDAR.1995.599023
Relational dependency networks Introduction to Statistical Relational Learning, 2007. ,
Markov Logic: An Interface Layer for Artificial Intelligence, Synthesis Lectures on Artificial Intelligence and Machine Learning, vol.3, issue.1, pp.1-155, 2009. ,
DOI : 10.2200/S00206ED1V01Y200907AIM007
Bayesian logic programming: theory and tool, Statistical Relational Learning, p.291, 2007. ,
Learning probabilistic relational models, In: IJCAI, vol.99, pp.1300-1309, 1999. ,
Discriminative training of Markov logic networks, In: AAAI, vol.5, pp.868-873, 2005. ,
Recursive random fields, IJCAI, pp.950-955, 2007. ,
machine., The Annals of Statistics, vol.29, issue.5, pp.1189-1232, 2001. ,
DOI : 10.1214/aos/1013203451
Online handwriting recognition using multiple pattern class models, 2000. ,
Fuzzy feature description of handwriting patterns, Pattern Recognition, vol.30, issue.10, pp.1591-1604, 1997. ,
DOI : 10.1016/S0031-3203(97)00003-4
An overview of ensemble methods for binary classifiers in multi-class problems: Experimental study on one-vs-one and one-vs-all schemes, Pattern Recognition, vol.44, issue.8, pp.44-1761, 2011. ,
DOI : 10.1016/j.patcog.2011.01.017
IBM UB 1: a dual mode unconstrained English handwriting dataset, Proceedings of the Twelfth International Conference on Document Analysis and Recognition 2013, pp.13-17, 2013. ,
UNIPEN project of on-line data exchange and recognizer benchmarks, Proceedings of the 12th IAPR International Conference on Pattern Recognition (Cat. No.94CH3440-5), pp.29-33, 1994. ,
DOI : 10.1109/ICPR.1994.576870
Performance evaluation of pattern classifiers for handwritten character recognition, International Journal on Document Analysis and Recognition, vol.4, issue.3, pp.191-204, 2002. ,
DOI : 10.1007/s100320200076
Online Handwritten Cursive Word Recognition Using Segmentation-Free MRF in Combination with P2DBMN-MQDF, 2013 12th International Conference on Document Analysis and Recognition, pp.349-353, 2013. ,
DOI : 10.1109/ICDAR.2013.77
Statistical and neural classification of handwritten numerals: a comparative study, Proceedings., 11th IAPR International Conference on Pattern Recognition. Vol.II. Conference B: Pattern Recognition Methodology and Systems, pp.643-646, 1992. ,
DOI : 10.1109/ICPR.1992.201859
ProbLog: a probabilistic Prolog and its application in link discovery, Proceedings of the 20th International Joint Conference on Artificial Intelligence, pp.2468-2473, 2007. ,
Logic Programs with Annotated Disjunctions, ICLP 2004, pp.431-445, 2004. ,
DOI : 10.1007/978-3-540-27775-0_30
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.69.6404
Logic programming, abduction and probability, New Generation Computing, vol.7, issue.1, pp.377-400, 1993. ,
DOI : 10.1007/BF03037184
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.51.6513
A viterbi-like algorithm and EM learning for statistical abduction, Proceedings of Workshop on Fusion of Domain Knowledge with Data for Decision Support, 2000. ,
DOI : 10.1007/3-540-45884-0_11
Abstract, Theory and Practice of Logic Programming, vol.15, issue.2-3, pp.235-262, 2011. ,
DOI : 10.1017/S1471068410000566
Approximate Inference for Logic Programs with Annotated Disjunctions, ILP 2010, pp.30-37, 2011. ,
DOI : 10.1007/978-3-642-21295-6_7
Abstract, Theory and Practice of Logic Programming, vol.35, issue.03, pp.358-40110, 2015. ,
DOI : 10.1017/S1471068411000664
Inference in probabilistic logic programs using weighted CNF's, Proceedings of the 27th Conference on Uncertainty in Artificial Intelligence, pp.211-220, 2011. ,
Constraints for probabilistic logic programming, Proceedings of the NIPS Probabilistic Programming Workshop, 2012. ,
A statistical learning method for logic programs with distribution semantics, Proceedings of the 12th International Conference on Logic Programming (ICLP95), pp.715-729, 1995. ,
CP-logic: A language of causal probabilistic events and its relation to logic programming. Theory Pract. Logic Prog, pp.245-308, 2009. ,
On continuous distributions and parameter estimation in probabilistic logic programs, 2011. ,
Introduction to Statistical Relational Learning (Adaptive Computation and Machine Learning), 2007. ,
Probabilistic Graphical Models: Principles and Techniques, 2009. ,
Modeling and Reasoning with Bayesian Networks Chapter, 2009. ,
DOI : 10.1017/cbo9780511811357
Max-margin markov networks, Proceedings of Neural Information Processing Systems, 2003. ,
Markov logic networks, Machine Learning, vol.23, issue.1-2, pp.107-136, 2006. ,
DOI : 10.1007/s10994-006-5833-1
Solving map exactly by searching on compiled arithmetic circuits, Proceedings of the 21st National Conference on Artificial Intelligence (AAAI-06), pp.143-148, 2006. ,
Inference and learning for directed probabilistic logic models, 2011. ,
Dedicated tabling for a probabilistic setting, ICLP (Tech. Communications of LIPIcs., Schloss Dagstuhl -Leibniz-Zentrum fuer Informatik, pp.124-133, 2010. ,
New advances in compiling CNF into decomposable negation normal form, Proceedings of the 16th European Conference on Artificial Intelligence, pp.328-332, 2004. ,
A compiler for deterministic, decomposable negation normal form, AAAI/IAAI, pp.627-634, 2002. ,
CP-logic theory inference with contextual variable elimination and comparison to BDD based inference methods Learning recursive patterns for biomedical information extraction, Proceedings of 19th International Conference of Inductive Logic Programming ILP 2006, pp.96-109, 2007. ,
Automated Discovery of Food Webs from Ecological Data Using Logic-Based Machine Learning, PLoS ONE, vol.7, issue.12, p.29028, 2011. ,
DOI : 10.1371/journal.pone.0029028.s001
How might we model an ecosystem?, Ecological Modelling, vol.220, issue.17, pp.1935-1949, 2009. ,
DOI : 10.1016/j.ecolmodel.2009.04.021
Intraguild predation in winter wheat: prey choice by a common epigeal carabid consuming spiders, Journal of Applied Ecology, vol.74, issue.1, pp.271-279, 2013. ,
DOI : 10.1111/1365-2664.12008
Machine learning in ecosystem informatics and sustainability, Proceedings of the 21st International Joint Conference on Artificial Intelligence, pp.8-13, 2009. ,
Invertebrate responses to the management of genetically modified herbicide-tolerant and conventional spring crops. ii. within-field epigeal and aerial arthropods, Philos. Trans. R. Soc. Lond. Ser. B Biol. Sci, vol.358, p.1863, 1439. ,
Discovering rules by metalevel abduction, ILP 2009, pp.49-64 ,
DOI : 10.1007/978-3-642-13840-9_6
Meta-interpretive learning of higher-order dyadic datalog: predicate invention revisited, Proceedings of the 23rd International Joint Conference Artificial Intelligence (IJCAI 2013), pp.1551-1557, 2013. ,
DOI : 10.1007/s10994-014-5471-y
Meta-interpretive learning: application to grammatical inference, Machine Learning, vol.2, issue.2, pp.25-49, 2014. ,
DOI : 10.1007/s10994-013-5358-3
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.295.5465
Theory Completion Using Inverse Entailment, ILP 2000, p.130, 2000. ,
Meta-interpretive learning of higher-order dyadic datalog: predicate invention revisited, Machine Learning, vol.27, issue.2, pp.49-7310, 2015. ,
Machine Learning a Probabilistic Network of Ecological Interactions, ILP 2011, pp.332-346, 2012. ,
DOI : 10.1007/978-3-642-31951-8_28
Construction and Validation of Food Webs Using Logic-Based Machine Learning and Text Mining, Adv. Ecol. Res, vol.49, pp.225-289, 2013. ,
DOI : 10.1016/B978-0-12-420002-9.00004-4
Using PageRank to Locally Partition a Graph, Internet Mathematics, vol.4, issue.1, pp.35-64, 2007. ,
DOI : 10.1080/15427951.2007.10129139
PageRank and the random surfer model, Proceedings of the 19th Annual ACM-SIAM Symposium on Discrete algorithms, 2008. ,
Stochastic logic programs: sampling, inference and applications, Proceedings of the 16th Conference on Uncertainty in Artificial Intelligence, 2000. ,
Probabilistic Inductive Logic Programming, Probabilistic Inductive Logic Programming, pp.1-27, 2008. ,
An Introduction to Statistical Relational Learning, 2007. ,
Stochastic logic programs. Adv. inductive logic prog, pp.254-264, 1996. ,
The PageRank citation ranking: bringing order to the web, 1999. ,
Adventures in Stochastic Processes, 1992. ,
DOI : 10.1007/978-1-4612-0387-2
Programming with personalized pagerank, Proceedings of the 22nd ACM international conference on Conference on information & knowledge management, CIKM '13, 2013. ,
DOI : 10.1145/2505515.2505573
ProPPR: Efficient first-order probabilistic logic programming for structure discovery, parameter learning, and scalable inference In: AAAI Workshop on Statistical Relational Artificial Intelligence (StaRAI 2014) (2014) jan.ramon@cs.kuleuven.be References 1 Critical assessment of automated flow cytometry data analysis techniques, Nat. Methods, vol.10, issue.3, pp.228-238, 2013. ,
Rapid cell population identification in flow cytometry data, Cytometry Part A, vol.5, issue.1, pp.6-13, 2011. ,
DOI : 10.1002/cyto.a.21007
Top-down induction of clustering trees, Proceedings of the 15th International Conference on Machine Learning, pp.55-63, 1998. ,
Aggregation versus selection bias, and relational neural networks, IJCAI-2003 Workshop on Learning Statistical Models from Relational Data, p.2003, 2003. ,
Incremental construction of complex aggregates: Counting over a secondary table, Online Preprints of 23th International Conference on Inductive Logic Programming, pp.1-6, 2013. ,
Merging Mixture Components for Cell Population Identification in Flow Cytometry, Advances in Bioinformatics, vol.59, issue.4, p.12, 2009. ,
DOI : 10.1002/cyto.a.20754
A Method for Multi-relational Classification Using Single and Multi-feature Aggregation Functions, PKDD 2007, pp.430-437, 2007. ,
DOI : 10.1007/978-3-540-74976-9_43
Feature Discovery with Type Extension Trees, ILP 2008, pp.122-139 ,
DOI : 10.1007/978-3-540-85928-4_13
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.217.2949
Interpreting flow cytometry data: a guide for the perplexed, Nature Immunology, vol.45, issue.7, pp.681-685, 2006. ,
DOI : 10.1038/ni0706-681
Type Extension Trees for feature construction and learning in relational domains, Artificial Intelligence, vol.204, pp.30-55, 2013. ,
DOI : 10.1016/j.artint.2013.08.002
Involving aggregate functions in multirelational search, PKDD 2002, p.287, 2002. ,
Probabilistic Relational Models, ILP 1999, p.3, 1999. ,
DOI : 10.1007/3-540-48751-4_1
URL : http://ai.stanford.edu/~koller/Papers/Getoor+al:SRL07.pdf
Facets of aggregation approaches to propositionalization, Proceedings of the Work-in-Progress Track at the 13th International Conference on Inductive Logic Programming, pp.30-39, 2003. ,
Inductive Logic Programming, 1992. ,
Learning relational probability trees, Proceedings of the ninth ACM SIGKDD international conference on Knowledge discovery and data mining , KDD '03, pp.625-630, 2003. ,
DOI : 10.1145/956750.956830
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.385.1639
Aggregation-based feature invention and relational concept classes, Proceedings of the ninth ACM SIGKDD international conference on Knowledge discovery and data mining , KDD '03, pp.167-176, 2003. ,
DOI : 10.1145/956750.956772
URL : http://archive.nyu.edu/bitstream/2451/27768/2/CPP-03-03.pdf
Comparing the use of background knowledge by inductive logic programming systems, Proceedings of the 5th International Workshop on Inductive Logic Programming, pp.199-230, 1995. ,
Misty Mountain clustering: application to fast unsupervised flow cytometry gating, BMC Bioinformatics, vol.11, issue.1, p.502, 2010. ,
DOI : 10.1186/1471-2105-11-502
Classifying Relational Data with Neural Networks, ILP 2005, pp.384-396, 2005. ,
DOI : 10.1007/11536314_23
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.59.9603
First order random forests: Learning relational classifiers with complex aggregates, Machine Learning, vol.37, issue.3, pp.1-3, 2006. ,
DOI : 10.1007/s10994-006-8713-9
Refining Aggregate Conditions in Relational Learning, PKDD 2006, pp.383-394, 2006. ,
DOI : 10.1007/11871637_37
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.69.4422
Data reduction for spectral clustering to analyze high throughput flow cytometry data Fast discovery of association rules, Advances in Knowledge Discovery and Data Mining, pp.307-328, 1996. ,
A polynomial time algorithm for finding a largest common subgraph of almost trees of bounded degree, IEICE Trans. Fundam. Electron. Commun. Comput. Sci, vol.76, issue.9, pp.1488-1493, 1993. ,
Indexing and mining free trees, Third IEEE International Conference on Data Mining, pp.509-512, 2003. ,
DOI : 10.1109/ICDM.2003.1250964
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.58.7301
Logical and Relational Learning. Cognitive Technologies, 2008. ,
Graph Theory, 2012. ,
Mining closed patterns in relational, graph and network data, Annals of Mathematics and Artificial Intelligence, vol.4, issue.4, pp.315-342, 2013. ,
DOI : 10.1007/s10472-012-9324-8
URL : https://hal.archives-ouvertes.fr/hal-00754967
Subsumption and implication, Information Processing Letters, vol.24, issue.2, pp.109-111, 1987. ,
DOI : 10.1016/0020-0190(87)90103-7
Subgraph isomorphism, log-bounded fragmentation, and graphs of (locally) bounded treewidth, Journal of Computer and System Sciences, vol.73, issue.5, pp.755-768, 2007. ,
DOI : 10.1016/j.jcss.2007.01.003
Mining Frequent Patterns without Candidate Generation: A Frequent-Pattern Tree Approach, Data Mining and Knowledge Discovery, vol.8, issue.1, pp.53-87, 2004. ,
DOI : 10.1023/B:DAMI.0000005258.31418.83
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.3.2424
Graph Theory, 1994. ,
An $n^{5/2} $ Algorithm for Maximum Matchings in Bipartite Graphs, SIAM Journal on Computing, vol.2, issue.4, pp.225-231, 1973. ,
DOI : 10.1137/0202019
Efficient frequent connected subgraph mining in graphs of bounded tree-width, Theor. Comput. Sci, vol.411, pp.31-33, 2010. ,
Frequent subgraph mining in outerplanar graphs, Proceedings of the 12th ACM SIGKDD international conference on Knowledge discovery and data mining , KDD '06, pp.472-508, 2010. ,
DOI : 10.1145/1150402.1150427
Learning logic programs with structured background knowledge??????An extended abstract of this paper appeared in: L.??De Raedt (Ed.), Proceedings of the Fifth International Workshop on Inductive Logic Programming, Tokyo, Japan, 1995, pp. 53???76, Scientific Report of the Department of Computer Science, Katholieke Universiteit Leuven, and also in the post-conference volume: L.??De Raedt (Ed.), Advances in Inductive Logic Programming, IOS Press, Amsterdam/Ohmsha, Tokyo, 1996, pp. 172???191., Artificial Intelligence, vol.128, issue.1-2, pp.31-97, 2001. ,
DOI : 10.1016/S0004-3702(01)00062-5
On generating all maximal independent sets, Information Processing Letters, vol.27, issue.3, pp.119-123, 1988. ,
DOI : 10.1016/0020-0190(88)90065-8
On the complexity of finding iso- and other morphisms for partial k-trees, Discrete Mathematics, vol.108, issue.1-3, pp.343-364, 1992. ,
DOI : 10.1016/0012-365X(92)90687-B
Bound on backtrack algorithms for listing cycles, paths, and spanning trees, pp.237-252, 1975. ,
Faster subtree isomorphism, Proceedings of the Fifth Israeli Symposium on the Theory of Computing and Systems, pp.126-131, 1997. ,
DOI : 10.1006/jagm.1999.1044
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.114.1254
