Product Life Cycle Data Management: A Cross-Sectoral Review - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Gary Ford
  • Fonction : Auteur
  • PersonId : 991271
Tom Bartley
  • Fonction : Auteur
  • PersonId : 1000835
Joel Igba
  • Fonction : Auteur
  • PersonId : 1000836
Alison Turner
  • Fonction : Auteur
  • PersonId : 1000837
Chris Mcmahon
  • Fonction : Auteur
  • PersonId : 990037
The paper explores data management in the product life cycle of three engineering domains – civil/construction, marine and wind energy – each with distinct but potentially common issues. The approach has been to assess issues within each domain against the life cycle stages defined in ISO 15288 “Systems and software engineering - System life cycle processes”, i.e., Concept, Development, Utilisation, Support and Retirement. These were then assimilated and comparisons drawn to identify common problems and areas that appear particular to the do-main. The paper presents a position statement, taken from the experience of practitioners in each of the relevant sectors; the purpose is to understand if there may be opportunities for cross-sectoral learning.
978-3-642-41501-2_7_Chapter.pdf (380.44 Ko) Télécharger le fichier
hal-01461921 , version 1 (08-02-2017)
Paternité
Gary Ford, Tom Bartley, Joel Igba, Alison Turner, Chris Mcmahon. Product Life Cycle Data Management: A Cross-Sectoral Review. 10th Product Lifecycle Management for Society (PLM), Jul 2013, Nantes, France. pp.58-67, ⟨10.1007/978-3-642-41501-2_7⟩. ⟨hal-01461921⟩
91 Consultations
185 Téléchargements
