Methods for investigating the sensitivity of joint resultants to body segment parameter variations, Journal of Biomechanics, vol.29, issue.5, pp.651-654, 1996. ,
DOI : 10.1016/0021-9290(95)00118-2
Influence of body segments??? parameters estimation models on inverse dynamics solutions during gait, Journal of Biomechanics, vol.39, issue.8, pp.1531-1537, 2006. ,
DOI : 10.1016/j.jbiomech.2005.04.014
URL : https://hal.archives-ouvertes.fr/hal-00091846
Investigation of inertial properties of the human body, 1975. ,
Space requirements of the seated operator: geometrical, kinematic, and mechanical aspects of the body, with special reference to the limbs, 1955. ,
Adjustments to McConville et al. and Young et al. body segment inertial parameters, Journal of Biomechanics, vol.40, issue.3, pp.543-53, 2007. ,
DOI : 10.1016/j.jbiomech.2006.02.013
Adjustments to Zatsiorsky-Seluyanov's segment inertia parameters, Journal of Biomechanics, vol.29, issue.9, pp.1223-1230, 1996. ,
DOI : 10.1016/0021-9290(95)00178-6
The mass and inertia characteristics of the main segments of the human body, Biomechanics viii-b, vol.56, issue.2, pp.1152-1159, 1983. ,
In vivo body segment inertial parameters determination using a gamme-scanner method. Biomechanics of human movement: Applications in rehabilitation, sports and ergonomics pp, pp.196-202, 1990. ,
Estimation of the biomechanical properties of three body types using a photogrammetric method, Journal of Biomechanics, vol.11, issue.8-9, pp.349-358, 1978. ,
DOI : 10.1016/0021-9290(78)90069-6
Inertial properties of the human trunk of males determined from magnetic resonance imaging, Annals of Biomedical Engineering, vol.22, issue.6/7, pp.692-706, 1994. ,
DOI : 10.1007/BF02368294
Estimating subject-specific body segment parameters using a 3-dimensional modeller program, Journal of Biomechanics, vol.41, issue.16, pp.3506-3510, 2008. ,
DOI : 10.1016/j.jbiomech.2008.09.021
Selection of Body Segment Parameters by Optimization Methods, Journal of Biomechanical Engineering, vol.104, issue.1, pp.38-44, 1982. ,
DOI : 10.1115/1.3138301
Identification of Human Mass Properties From Motion, IFAC Proceedings Volumes (IFAC- PapersOnline), pp.988-993, 2009. ,
DOI : 10.3182/20090706-3-FR-2004.00164
An individual and dynamic Body Segment Inertial Parameter validation method using ground reaction forces, Journal of Biomechanics, vol.47, issue.7, pp.1577-1581, 2014. ,
DOI : 10.1016/j.jbiomech.2014.03.004
URL : https://hal.archives-ouvertes.fr/hal-01342183
Are Patient-Specific Joint and Inertial Parameters Necessary for Accurate Inverse Dynamics Analyses of Gait?, IEEE Transactions on Biomedical Engineering, vol.54, issue.5, pp.782-793, 2007. ,
DOI : 10.1109/TBME.2006.889187
Estimating human body segment parameters using motion capture data, 2010 4th International Universal Communication Symposium, pp.243-249, 2010. ,
DOI : 10.1109/IUCS.2010.5666224
The effect of kinematic constraints in the inverse dynamics problem in biomechanics, Multibody System Dynamics, vol.28, issue.3, 2016. ,
DOI : 10.1007/s11044-016-9508-9
What you see may not be what you get: a brief, nontechnical introduction to overfitting in regression-type models, Psychosomatic medicine, vol.66, issue.3, pp.411-421, 2004. ,
Analysis of different uncertainties in the inverse dynamic analysis of human gait. Mechanism and Machine Theory 58, pp.153-164, 2012. ,
Uncertainties in inverse dynamics solutions: A comprehensive analysis and an application to gait, Gait & Posture, vol.27, issue.4, pp.578-588, 2008. ,
DOI : 10.1016/j.gaitpost.2007.07.012
Kinematic Data Consistency in the Inverse Dynamic Analysis of Biomechanical Systems pp, pp.219-239, 2002. ,
ISB recommendation on definitions of joint coordinate system of various joints for the reporting of human joint motion???part I: ankle, hip, and spine, Journal of Biomechanics, vol.35, issue.4, pp.543-548, 2002. ,
DOI : 10.1016/S0021-9290(01)00222-6
ISB recommendation on definitions of joint coordinate systems of various joints for the reporting of human joint motion???Part II: shoulder, elbow, wrist and hand, Journal of Biomechanics, vol.38, issue.5, pp.981-992, 2005. ,
DOI : 10.1016/j.jbiomech.2004.05.042
Rigid Body Dynamics Algorithms, 2008. ,
DOI : 10.1007/978-0-387-74315-8
URL : http://hdl.handle.net/1885/25421
Dealing with modularity of multibody models, Computer Methods in Biomechanics and Biomedical Engineering, vol.18, issue.sup1, pp.2008-2009, 2015. ,
DOI : 10.1016/0021-9290(95)00017-C
URL : https://hal.archives-ouvertes.fr/hal-01174136
ISB recommendations for standardization in the reporting of kinematic data, Journal of Biomechanics, vol.28, issue.10, pp.1257-1261, 1995. ,
A Simple Method to Calibrate Kinematical Invariants: Application to Overhead Throwing, International Society of Biomechanics in Sports (ISBS), 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01150814
Biomechanics and motor control of human movement, 2009. ,
DOI : 10.1002/9780470549148
Analysis of musculoskeletal systems in the AnyBody Modeling System, Simulation Modelling Practice and Theory, vol.14, issue.8, pp.1100-1111, 2006. ,
DOI : 10.1016/j.simpat.2006.09.001
OpenSim: Open-Source Software to Create and Analyze Dynamic Simulations of Movement, IEEE Transactions on Biomedical Engineering, vol.54, issue.11, pp.1940-50, 2007. ,
DOI : 10.1109/TBME.2007.901024
Bone position estimation from skin marker co-ordinates using global optimisation with joint constraints, Journal of Biomechanics, vol.32, issue.2, pp.129-134, 1999. ,
DOI : 10.1016/S0021-9290(98)00158-4
Refinement of the upper limb joint kinematics and dynamics using a subject-specific closed-loop forearm model, Multibody System Dynamics, vol.45, issue.7, pp.413-438, 2015. ,
DOI : 10.1007/s11044-014-9421-z
A Least-Squares Estimation Approach to Improving the Precision of Inverse Dynamics Computations, Journal of Biomechanical Engineering, vol.120, issue.1, pp.148-159, 1998. ,
DOI : 10.1115/1.2834295
A weighted least squares method for inverse dynamic analysis, Computer Methods in Biomechanics and Biomedical Engineering, vol.11, issue.1, pp.3-9, 2008. ,
DOI : 10.1016/0141-1195(86)90098-7
Scaling of musculoskeletal models from static and dynamic trials, International Biomechanics, vol.8, issue.1, pp.1-11, 2015. ,
A finite element musculoskeletal model of the shoulder mechanism, Journal of Biomechanics, vol.27, issue.5, pp.551-69, 1994. ,
DOI : 10.1016/0021-9290(94)90065-5
A generic detailed rigid-body lumbar spine model, Journal of Biomechanics, vol.40, issue.6, pp.1219-1246, 2007. ,
DOI : 10.1016/j.jbiomech.2006.05.030
A numerical method for choosing motions with optimal excitation properties for identification of biped dynamics - An application to human, 2009 IEEE International Conference on Robotics and Automation, pp.1226-1231, 2009. ,
DOI : 10.1109/ROBOT.2009.5152264
A solidification procedure to facilitate kinematic analyses based on video system data, Journal of Biomechanics, vol.28, issue.7, pp.879-884, 1995. ,
DOI : 10.1016/0021-9290(95)95278-D
Studies of human locomotion: past, present and future, Journal of Biomechanics, vol.33, issue.10, pp.1217-1224, 2000. ,
DOI : 10.1016/S0021-9290(00)00061-0
