Nonlinear Unknown Input Observability: The Analytic Solution in the case of a Single Unknown Input - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2017
Observabilité non linéaire avec entrées inconnues: Solution Analytique dans le cas d’une seule entrée inconnue
This work presents the analytic solution of a fundamental open problem in the framework of nonlinear observability, which is the unknown input observability problem (UIO problem). The solution here provided holds in the case of a single unknown input. The first part of the work presents this analytic solution, namely the analytic criterion that allows us to obtain the observability of a nonlinear system in presence of a single unknown input and multiple known inputs. As for the observability rank condition, the proposed analytic criterion is based on the computation of the observable codistribution. Similarly to the case of only known inputs, the observable codistribution is obtained by recursively computing the Lie derivatives of the outputs along the vector fields that characterize the dynamics. However, in correspondence of the unknown input, the corresponding vector field must be suitably rescaled. Additionally, the Lie derivatives of the outputs must also be computed along a new set of vector fields that are obtained by recursively performing suitable Lie bracketing of the vector fields that define the dynamics. In practice, the entire observable codistribution is obtained by a very simple recursive algorithm. Finally, it is shown that the recursive algorithm converges in a finite number of steps and the criterion to establish that the convergence has been reached is provided. The proposed analytic extension of the observability rank condition is illustrated by checking the weak local observability of several nonlinear systems driven by multiple known inputs and a single unknown input. For these systems, extensive simulations are also provided. It is shown that, a simple estimator based on an Extended Kalman Filter, provides results that agree with what we could expect from the observability analysis. Finally, it is shown that the analytic criterion introduced in this work is not only a key analytical tool to automatically obtain the state observability but it can be also a fundamental tool to design an appropriate estimator.
Ce travail présente la solution analytique d’un problème ouvert fondamental dans le cadre de l’observabilité non linéaire, qui est le problème de l’observabilité non linéaire quand une partie (voire la totalité) des entrées du système est inconnu. La solution ici fournie est valable dans le cas d’une seule entrée inconnue. La première partie du travail présente cette solution analytique, c’est à dire le critère analytique qui permet d’obtenir l’observabilité d’un système non linéaire en présence d’une seule entrée inconnue et de multiples entrées connues. Pareil que pour la solution dans le cas sans entrées inconnues, le critère analytique proposé est basé sur le calcul de la codistribution observable. De même pour le cas des entrées connues seulement, la codistribution observable est obtenue en calculant de façon récursive les dérivées de Lie des sorties du système le long des champs vectoriels qui caractérisent la dynamique. Cependant, en correspondance de l’entrée inconnue, le champ vectoriel correspondant doit être réétalonné de manière appropriée. De plus, les dérivées de Lie des sorties du système doivent également être calculées le long d’un nouvel ensemble de champs vectoriels qui sont obtenus en effectuant récursivement un bracketing de Lie approprié des champs vectoriels qui définissent la dynamique. En pratique, la totalité de la codistribution observable est obtenue par un algorithme récursif très simple. Enfin, il est montré que l’algorithme récursif converge en un nombre fini d’étapes et que le critère pour établir que la convergence a été atteinte est fourni. La solution analytique proposée est illustrée par l’étude de l’observabilité de plusieurs systèmes non linéaires pilotés par plusieurs entrées connues et une seule entrée inconnue. Pour ces systèmes, des simulations sont également fournies. Il est montré qu’un estimateur simple basé sur un filtre de Kalman étendu fournit des résultats qui concordent avec ce que l’on pourrait attendre de l’analyse d’observabilité. Enfin, il est montré que le critère analytique introduit dans ce travail n’est pas seulement un outil analytique clé pour obtenir automatiquement l’observabilité de l’état mais il peut aussi être un outil fondamental pour concevoir un estimateur approprié.
RR-9027.pdf (1.66 Mo) Télécharger le fichier
hal-01464523 , version 1 (10-02-2017)
hal-01464523 , version 2 (05-04-2017)
hal-01464523 , version 3 (11-04-2017)
  • HAL Id : hal-01464523 , version 1
Agostino Martinelli. Nonlinear Unknown Input Observability: The Analytic Solution in the case of a Single Unknown Input. [Research Report] RR-9027, INRIA Grenoble - Rhone-Alpes - CHROMA Team. 2017, pp.55. ⟨hal-01464523v1⟩
558 Consultations
229 Téléchargements
