Towards Virtualization Concepts for Novel Automotive HMI Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Simon Gansel
  • Fonction : Auteur
  • PersonId : 1001376
Stephan Schnitzer
  • Fonction : Auteur
  • PersonId : 1001377
Frank Dürr
  • Fonction : Auteur
  • PersonId : 1001378
Kurt Rothermel
  • Fonction : Auteur
  • PersonId : 1001379
Christian Maihöfer
  • Fonction : Auteur
  • PersonId : 1001380
Many innovations in the automotive industry are based on electronics and software, which has led to a steady increase of electronic control units (ECU) in cars. This brought up serious scalability and complexity issues in terms of cost, installation space, and energy consumption. In order to tackle these problems, there is a strong interest to consolidate ECUs using virtualization technologies. However, current efforts largely neglect legal constraints and certification issues and the resulting technical requirements.In this paper, we focus on the consolidation of graphics hardware through virtualization, which received a lot of interest in the car industry due to the growing relevance of HMI systems such as head unit and instrument cluster in modern cars. First, we investigate relevant ISO standards and legal requirements and derive seven technical requirements for a virtualized automotive HMI system. Based on these requirements, we present the concept for a Virtualized Automotive Graphics System (VAGS) that allows for the consolidation of mixed-criticality graphics ECUs.
978-3-642-38853-8_18_Chapter.pdf (192.56 Ko) Télécharger le fichier
hal-01466673 , version 1 (13-02-2017)
Paternité
Simon Gansel, Stephan Schnitzer, Frank Dürr, Kurt Rothermel, Christian Maihöfer. Towards Virtualization Concepts for Novel Automotive HMI Systems. 4th International Embedded Systems Symposium (IESS), Jun 2013, Paderborn, Germany. pp.193-204, ⟨10.1007/978-3-642-38853-8_18⟩. ⟨hal-01466673⟩
180 Consultations
202 Téléchargements
