Designing Reliable Systems from Unreliable Components: The Challenges of Transistor Variability and Degradation, IEEE Micro, vol.25, issue.6, pp.10-16, 2005. ,
DOI : 10.1109/MM.2005.110
Single event upset at ground level, IEEE Transactions on Nuclear Science, vol.43, issue.6, pp.2742-2750, 1996. ,
DOI : 10.1109/23.556861
Neutron-induced soft-errors in graphic processing units. 2012, IEEE Radiation Effects Data Workshop. (REDW '12) IEEE, p.pp ,
Dark silicon and the end of multicore scaling, ISCA '11: Proc. of the 38th Int. Symp. on Comp. Arch, pp.365-376, 2011. ,
Expecting the Unexpected - Radiation Hardened Software, Infotech@Aerospace, 2005. ,
DOI : 10.2514/6.2005-7088
Software-Implemented Hardware Fault Tolerance, 2006. ,
ACCE: Automatic correction of control-flow errors, 2007 IEEE International Test Conference, pp.1-10, 2007. ,
DOI : 10.1109/TEST.2007.4437639
MiBench: A free, commercially representative embedded benchmark suite, Proceedings of the Fourth Annual IEEE International Workshop on Workload Characterization. WWC-4 (Cat. No.01EX538), pp.3-14, 2001. ,
DOI : 10.1109/WWC.2001.990739
LLVM: A compilation framework for lifelong program analysis & transformation, International Symposium on Code Generation and Optimization, 2004. CGO 2004., p.75, 2004. ,
DOI : 10.1109/CGO.2004.1281665
A design methodology for software fault injection in embedded systems, DCIA '98: Proc. of the Workshop on Dependable Computing and its applications ,
Fast and Effective Orchestration of Compiler Optimizations for Automatic Performance Tuning, Proceedings of the International Symposium on Code Generation and Optimization (CGO '06, pp.319-332, 2006. ,
Cole, Proceedings of the sixth annual IEEE/ACM international symposium on Code generation and optimization , CGO '08, pp.165-174, 2008. ,
DOI : 10.1145/1356058.1356080
A systematic methodology to compute the architectural vulnerability factors for a high-performance microprocessor, 22nd Digital Avionics Systems Conference. Proceedings (Cat. No.03CH37449), pp.29-41, 2003. ,
DOI : 10.1109/MICRO.2003.1253181
Evaluating the Effects of Compiler Optimisations on AVF, Workshop on Interaction Between Compilers and Computer Architecture (INTERACT-12), 2008. ,
Impact of Software Optimization on Variable Lifetimes in a Microprocessor-Based System, 2011 Sixth IEEE International Symposium on Electronic Design, Test and Application, pp.56-61, 2011. ,
DOI : 10.1109/DELTA.2011.20
URL : https://hal.archives-ouvertes.fr/hal-00643932
Decimal hamming: a novel softwareimplemented technique to cope with soft errors, Proc. of the 26 th IEEE Int. Symp. on Defect and Fault Tolerance in VLSI and Nanotech. Sys., DFT '11. IEEE, pp.11-17, 2011. ,
