New interface
Conference papers
Conformal hexahedral mesh coarsening by agglomeration
Pierre Cargemel 1 Youssef Mesri 1 Hervé Guillard 2, 3
2 CASTOR - Control, Analysis and Simulations for TOkamak Research
CRISAM - Inria Sophia Antipolis - Méditerranée , JAD - Laboratoire Jean Alexandre Dieudonné
Abstract : Reservoir simulation involves to compute dynamic flow of different phases in a porous medium. The initial state of the reservoir is usually precomputed via geo-statistics methods, extrapolating measures of the terrain. so, the input of reservoir simulation is given as a fine mesh containing heterogeneous data In this paper, we describe an agglomeration strategy, to dynamically coarsen this fine hex-dominant mesh. The adaptivity may be driven by physics and/or geometric estimators. Ideally, the coars- ening should be applied locally in low gradient regions, whereas high gradient regions keep the fine mesh.
Complete list of metadata
Cited literature [5 references]  Display  Hide  Download
https://hal.inria.fr/hal-01466938
Contributor : Herve Guillard Connect in order to contact the contributor
Submitted on : Tuesday, January 6, 2015 - 3:04:20 PM
Last modification on : Thursday, August 4, 2022 - 4:58:36 PM
Long-term archiving on: : Friday, September 11, 2015 - 12:40:32 AM
File
IMR23_ResearchNote6_Cargemel.p...
Identifiers
  • HAL Id : hal-01466938, version 2
Collections
Citation
Pierre Cargemel, Youssef Mesri, Hervé Guillard. Conformal hexahedral mesh coarsening by agglomeration. 23rd International Meshing Roundtable, Sandia National laboratory, Oct 2014, London, United Kingdom. ⟨hal-01466938v2⟩
Share
Metrics
Record views
689
Files downloads
169
