Upscaling Multiphase Flow Simulations in Heterogeneous Stratified Reservoirs by Optimal Layering, SPE Annual Technical Conference and Exhibition, pp.185-195, 2004. ,
DOI : 10.2118/90412-MS
The Arcane development framework, Proceedings of the 8th workshop on Parallel/High-Performance Object-Oriented Scientific Computing, POOSC '09, 2009. ,
DOI : 10.1145/1595655.1595659
The spatial twist continuum: A connectivity based method for representing all hexaedral finite element meshes. Finite Element in Analysis and Design, pp.137-149, 1997. ,
Adaptative mesh coarsening for quadrilateral and hexahedral meshes. Finite Element in Analysis and Design, pp.17-32, 2010. ,
The whisker algorithm: A connectivity-based method for constructing all-hexaedral finite element meshes, Internationnal Journal for Numerical Methods in Engineering, 1996. ,
