A Method and Toolkit for Digital Musical Instruments: Generating Ideas and Prototypes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE MultiMedia Année : 2017
Digital musical instruments (DMIs) make up a class of devices in which gestural control and sound production are physically decoupled, but digitally mapped. This work discusses aspects of DMI design by focusing on the complexity of the design space and the importance of prototyping cycles. The authors' research questions cover how to provide an initial path for generating DMI ideas and how to reduce the time and effort required to build functional DMI prototypes. To address these questions, they propose a new methodology and an associated physical prototyping toolkit, which has building blocks inspired by of existing instruments. Preliminary tests with musicians and DMI designers revealed a strong potential for its use in the development of DMIs, and also uncovered limitations of the current toolkit. This article is part of a special issue on multimedia technologies for enriched music.
Fichier non déposé
hal-01467105 , version 1 (14-02-2017)
Filipe Calegario, Stéphane Huot, Marcelo M. Wanderley, Giordano Cabral, Geber Ramalho. A Method and Toolkit for Digital Musical Instruments: Generating Ideas and Prototypes. IEEE MultiMedia, 2017, Enriching the Music Experience, 24 (1), pp.9. ⟨10.1109/MMUL.2017.18⟩. ⟨hal-01467105⟩
269 Consultations
0 Téléchargements
