Eulerian multi-fluid models for the simulation of dynamics and coalescence of particles in solid propellant combustion, Journal of Computational Physics, vol.234, issue.C, pp.230-262, 2013. ,
DOI : 10.1016/j.jcp.2012.09.025
URL : https://hal.archives-ouvertes.fr/hal-00618806
A particle-fluid numerical model for liquid sprays, Journal of Computational Physics, vol.35, issue.2, pp.229-253, 1980. ,
Numerical calculation of multiphase fluid flow, Journal of Computational Physics, vol.17, issue.1, pp.19-52, 1975. ,
DOI : 10.1016/0021-9991(75)90061-3
Simulation of fluid and particles flows: Asymptotic preserving schemes for bubbling and flowing regimes, Journal of Computational Physics, vol.227, issue.16, pp.7929-7951, 2008. ,
DOI : 10.1016/j.jcp.2008.05.002
URL : https://hal.archives-ouvertes.fr/hal-00768398
Modélisation mathématique etétudeetétude numérique d'un aérosol ApplicationàApplicationà la simulation du transport de particules depoussì ere en cas d'accident de perte de vide dans ITER, 2009. ,
Kinetic theory study of steady evaporation from a spherical condensed phase containing inert solid particles, Physics of Fluids, vol.9, issue.1, p.211, 1997. ,
DOI : 10.1063/1.869163
Modelling and numerical methods for the dynamics of impurities in a gas, International Journal for Numerical Methods in Fluids, vol.77, issue.6, pp.693-713, 2006. ,
DOI : 10.1002/fld.1638
Basics of Plume Impingement Analysis for Small Chemical and Cold Gas Thrusters. Models and Computational Methods for Rarefied Flows, AVT-194 RTO AVT/VKI, 2011. ,
The Boltzmann Equation and Its Applications, 1988. ,
DOI : 10.1007/978-1-4612-1039-9
Molecular Gas Dynamics and the Direct Simulation of Gas Flows. Oxford engineering science series, 1994. ,
A Model for Collision Processes in Gases. I. Small Amplitude Processes in Charged and Neutral One-Component Systems, Physical Review, vol.94, issue.3, pp.511-525, 1954. ,
DOI : 10.1103/PhysRev.94.511
Kinetic Theory of Shock Structure Using an Ellipsoidal Distribution Function, Rarefied Gas Dynamics, p.193, 1965. ,
Abstract, Communications in Computational Physics, vol.22, issue.03, pp.801-840, 2016. ,
DOI : 10.1512/iumj.2004.53.2509
The multiphase particle-in-cell (MP-PIC) method for dense particulate flows, International Journal of Multiphase Flow, vol.22, issue.2, 1996. ,
DOI : 10.1016/0301-9322(95)00072-0
Sediment flow in inclined vessels calculated using a multiphase particle-in-cell model for dense particle flows, International Journal of Multiphase Flow, vol.24, issue.8, 1998. ,
DOI : 10.1016/S0301-9322(98)00030-5
Modeling and numerical simulation of particulate flows by the Eulerian???Lagrangian approach, International Journal of Multiphase Flow, vol.27, issue.10, 2001. ,
DOI : 10.1016/S0301-9322(01)00021-0
A quadrature-based moment method for dilute fluid-particle flows, Journal of Computational Physics, vol.227, issue.4, pp.2514-2539, 2008. ,
DOI : 10.1016/j.jcp.2007.10.026
The Formation of Vortices from a Surface of Discontinuity, Proceedings of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.134, issue.823, pp.170-192, 1931. ,
DOI : 10.1098/rspa.1931.0189
The Particle-in-cell Method for Hydrodynamic Calculatons, 1957. ,
Smoothed particle hydrodynamics: theory and application to non-spherical stars, Monthly Notices of the Royal Astronomical Society, vol.181, issue.3, pp.375-389, 1977. ,
DOI : 10.1093/mnras/181.3.375
A numerical approach to the testing of the fission hypothesis, The Astronomical Journal, vol.82, pp.1013-1024, 1977. ,
DOI : 10.1086/112164
Smoothed particle hydrodynamics, Reports on Progress in Physics, vol.68, issue.8, pp.1703-1759, 2005. ,
DOI : 10.1088/0034-4885/68/8/R01
A level set method for fluidstructure interactions with immersed surfaces. Mathematical models and methods in applied sciences, pp.415-438, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00103198
Vortex Methods: Theory and Practice, 2000. ,
DOI : 10.1017/CBO9780511526442
Vortex methods. I. Convergence in three dimensions, Mathematics of Computation, vol.39, issue.159, pp.1-27, 1982. ,
High-resolution simulations of the flow around an impulsively started cylinder using vortex methods, Journal of Fluid Mechanics, vol.29, issue.-1, pp.1-38, 1995. ,
DOI : 10.1016/0021-9991(80)90049-2
Particle methods revisited: a class of high order finite-difference methods, Comptes Rendus Mathematique, vol.343, issue.1, pp.51-56, 2006. ,
DOI : 10.1016/j.crma.2006.05.001
URL : https://hal.archives-ouvertes.fr/hal-00103200
Numerical comparison between the Boltzmann and ES-BGK models for rarefied gases, Computer Methods in Applied Mechanics and Engineering, vol.191, issue.31, pp.3369-3390, 2002. ,
DOI : 10.1016/S0045-7825(02)00253-0
URL : https://hal.archives-ouvertes.fr/inria-00072782
The effects of linear and quadratic drag on falling spheres: an undergraduate laboratory, European Journal of Physics, vol.26, issue.6, pp.1085-1091, 2005. ,
Pauline Lafitte, FrédéricLagoutì ere, and Beno??tBeno??t Merlet. Fluid-particles flows: a thin spray model with energy exchanges, 2009. ,
Accurate Asymptotic Preserving Boundary Conditions for Kinetic Equations on Cartesian Grids, Journal of Scientific Computing, vol.229, issue.20, pp.735-766, 2015. ,
DOI : 10.1007/s10915-015-9984-8
URL : https://hal.archives-ouvertes.fr/hal-00945761
Implicit-explicit Runge-Kutta methods for time-dependent partial differential equations, Applied Numerical Mathematics, vol.25, issue.2-3, pp.151-167, 1997. ,
DOI : 10.1016/S0168-9274(97)00056-1
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.48.1525
Additive Runge-Kutta schemes for convection-diffusion-reaction equations, Applied Numerical Mathematics, vol.44, issue.12, pp.139-141, 2003. ,
Implicit?Explicit Runge?Kutta Schemes and Applications to Hyperbolic Systems with Relaxation, Journal of Scientific Computing, vol.25, issue.1, pp.129-155, 2005. ,
DOI : 10.1007/bf02728986
URL : http://arxiv.org/abs/1009.2757
The Numerical Solution of Differential-Algebraic Systems by Runge-Kutta Methods, p.12339, 1989. ,
DOI : 10.1007/BFb0093947
Implicit???Explicit Schemes for BGK Kinetic Equations, Journal of Scientific Computing, vol.120, issue.1, pp.1-28, 2007. ,
DOI : 10.1007/s10915-006-9116-6
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.170.6387
An Asymptotic Preserving Scheme for the ES-BGK Model of the Boltzmann Equation, Journal of Scientific Computing, vol.120, issue.2, pp.204-224, 2010. ,
DOI : 10.1007/s10915-010-9394-x
A Time Dependent Domain Decomposition Method for a Multiscale Hydrodynamic-Kinetic System of Equations, 2011. ,
A study of singularity formation in a vortex sheet by the point-vortex approximation, Journal of Fluid Mechanics, vol.150, issue.-1, pp.65-93, 1986. ,
DOI : 10.1016/0021-9991(80)90040-6
Particle method: an efficient tool for direct numerical simulations of a high Schmidt number passive scalar in turbulent flow, Proceedings of the Summer Program 2012, pp.167-176, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00748132
On the Construction and Comparison of Difference Schemes, SIAM Journal on Numerical Analysis, vol.5, issue.3, pp.506-517, 1968. ,
DOI : 10.1137/0705041
Accurate, non-oscillatory, remeshing schemes for particle methods, Journal of Computational Physics, vol.231, issue.1, pp.152-172, 2012. ,
DOI : 10.1016/j.jcp.2011.09.005
URL : https://hal.archives-ouvertes.fr/hal-00588848
High order semi-Lagrangian particle methods for transport equations: numerical analysis and implementation issues, ESAIM: Mathematical Modelling and Numerical Analysis, vol.48, issue.4, pp.1029-1060, 2014. ,
DOI : 10.1051/m2an/2014009
URL : https://hal.archives-ouvertes.fr/hal-00991150
Simulation of Diluted Flow Regimes in Presence of Unsteady Boundaries, Finite Volumes for Complex Applications VII-Elliptic, Parabolic and Hyperbolic Problems, pp.801-808, 2014. ,
DOI : 10.1007/978-3-319-05591-6_80
Shock Front Width and Structure in Supersonic Granular Flows, Physical Review Letters, vol.101, issue.25, 2008. ,
DOI : 10.1103/PhysRevLett.101.254503
URL : https://hal.archives-ouvertes.fr/hal-00746027
On the movement of small particles suspended in stationary liquids required by the molecular-kinetic theory of heat, Annalen der Physik, vol.17, pp.549-56016, 1905. ,
