New interface
Preprints, Working Papers, ...
Analysis of a state constraint optimal control problem related to the modelling of coastal lagoons
Abstract : In this work, we study a non-autonomous optimal control problem under state constraints. The system under consideration describes the salt and volume concentration of a costal lagoon occasionally connected to the sea. The dynamics is non-autonomous in the sense that it takes into account two seasons (dry and hot). Our aim is to maximize the volume of the pumped water w.r.t. water consumption over one year, while fulfilling ecological constraint. We first characterize the set of initial conditions for which there exists a control function such that the corresponding trajectory satisfies the ecological constraint over one year. This allows us to explicit for any initial condition an optimal control policy maximizing the pumped water over one year.
Complete list of metadata
https://hal.inria.fr/hal-01468979
Contributor : Antoine Rousseau Connect in order to contact the contributor
Submitted on : Thursday, February 16, 2017 - 9:41:35 AM
Last modification on : Tuesday, October 25, 2022 - 4:22:17 PM
Identifiers
  • HAL Id : hal-01468979, version 1
Citation
Térence Bayen, Loïc Dagnas, Hector Ramirez Cabrera, Alain Rapaport, Antoine Rousseau, et al.. Analysis of a state constraint optimal control problem related to the modelling of coastal lagoons. 2017. ⟨hal-01468979⟩
Share
Metrics
Record views
592
