Semantic Segmentation of 3D Textured Meshes for Urban Scene Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ISPRS Journal of Photogrammetry and Remote Sensing Année : 2017
Classifying 3D measurement data has become a core problem in photogram-metry and 3D computer vision, since the rise of modern multiview geometry techniques, combined with affordable range sensors. We introduce a Markov Random Field-based approach for segmenting textured meshes generated via multi-view stereo into urban classes of interest. The input mesh is first partitioned into small clusters, referred to as superfacets, from which geometric and photometric features are computed. A random forest is then trained to predict the class of each superfacet as well as its similarity with the neighboring superfacets. Similarity is used to assign the weights of the Markov Random Field pairwise-potential and accounts for contextual information between the classes. The experimental results illustrate the efficacy and accuracy of the proposed framework.
JPRS_2017_Rouhani.pdf (37.82 Mo) Télécharger le fichier
Format : Figure, Image
hal-01469502 , version 1 (16-02-2017)
Mohammad Rouhani, Florent Lafarge, Pierre Alliez. Semantic Segmentation of 3D Textured Meshes for Urban Scene Analysis. ISPRS Journal of Photogrammetry and Remote Sensing, 2017, 123, pp.124 - 139. ⟨10.1016/j.isprsjprs.2016.12.001⟩. ⟨hal-01469502⟩
1130 Consultations
1166 Téléchargements
