Strictly correlated electrons in density-functional theory, Physical Review A, vol.59, issue.1, p.51, 1999. ,
DOI : 10.1103/PhysRevA.59.51
Strictly correlated electrons in density-functional theory: A general formulation with applications to spherical densities, Physical Review A, vol.75, issue.4, p.42511, 2007. ,
DOI : 10.1103/PhysRevA.75.042511
Electronic Zero-Point Oscillations in the Strong-Interaction Limit of Density Functional Theory, Journal of Chemical Theory and Computation, vol.5, issue.4, p.743, 2009. ,
DOI : 10.1021/ct8005248
Universal variational functionals of electron densities, first-order density matrices, and natural spin-orbitals and solution of the v-representability problem, Proceedings of the National Academy of Sciences, vol.76, issue.12, p.6062, 1979. ,
DOI : 10.1073/pnas.76.12.6062
Density Functional Theory and Optimal Transportation with Coulomb Cost, Communications on Pure and Applied Mathematics, vol.12, issue.3, p.548, 2013. ,
DOI : 10.1002/cpa.21437
URL : http://arxiv.org/abs/1104.0603
Strong Correlation in Kohn-Sham Density Functional Theory, Physical Review Letters, vol.109, issue.24, p.246402, 2012. ,
DOI : 10.1103/PhysRevLett.109.246402
Kohn-Sham density functional theory for quantum wires in arbitrary correlation regimes, Physical Review B, vol.87, issue.11, p.115146, 2013. ,
DOI : 10.1103/PhysRevB.87.115146
Wigner localization in quantum dots from Kohn-Sham density functional theory without symmetry breaking, Physical Review B, vol.89, issue.12, p.125106, 2014. ,
DOI : 10.1103/PhysRevB.89.125106
Multimarginal Optimal Transport Maps for One-dimensional Repulsive Costs, Journal canadien de math??matiques, vol.67, issue.2, p.350, 2015. ,
DOI : 10.4153/CJM-2014-011-x
Optimal-transport formulation of electronic density-functional theory, Physical Review A, vol.85, issue.6, p.62502, 2012. ,
DOI : 10.1103/PhysRevA.85.062502
Energy Densities in the Strong-Interaction Limit of Density Functional Theory, Journal of Chemical Theory and Computation, vol.8, issue.9, p.3097, 2012. ,
DOI : 10.1021/ct3003892
Exchange???Correlation Functionals via Local Interpolation along the Adiabatic Connection, Journal of Chemical Theory and Computation, vol.12, issue.6, p.2598, 2016. ,
DOI : 10.1021/acs.jctc.6b00177
URL : http://doi.org/10.1021/acs.jctc.6b00177
Density-Functional Theory for Strongly Correlated Bosonic and Fermionic Ultracold Dipolar and Ionic Gases, Physical Review Letters, vol.115, issue.3, p.33006, 2015. ,
DOI : 10.1103/PhysRevLett.115.033006
URL : http://arxiv.org/abs/1502.01469
Counterexamples in multimarginal optimal transport with Coulomb cost and spherically symmetric data, Mathematical Models and Methods in Applied Sciences, vol.26, issue.06, p.1025, 2016. ,
DOI : 10.1142/S021820251650024X
URL : http://arxiv.org/abs/1507.08522
Mémoire sur la théorie des déblais et des remblais, Histoire Acad. Sciences, p.1781 ,
Optimal transport with Coulomb cost. Approximation and duality, ESAIM: Mathematical Modelling and Numerical Analysis, vol.49, issue.6, p.1643, 2015. ,
DOI : 10.1051/m2an/2015035
Iterative Bregman Projections for Regularized Transportation Problems, SIAM Journal on Scientific Computing, vol.37, issue.2, p.1111, 2015. ,
DOI : 10.1137/141000439
URL : https://hal.archives-ouvertes.fr/hal-01096124
A Numerical Method to Solve Multi-Marginal Optimal Transport Problems with Coulomb Cost, Splitting Methods in Communication , Imaging, Science, and Engineering, pp.577-601 ,
DOI : 10.1007/978-3-319-41589-5_17
Numerical Methods for Multi-Marginal Opimal Transportation, 2016. ,
Positive contraction mappings for classical and quantum Schr??dinger systems, Journal of Mathematical Physics, vol.56, issue.3, p.33301, 2015. ,
DOI : 10.1063/1.4915289
URL : http://arxiv.org/abs/1405.6650
Improved Lieb-Oxford exchange-correlation inequality with a gradient correction, Physical Review A, vol.91, issue.2, p.22507, 2015. ,
DOI : 10.1103/PhysRevA.91.022507
Challenging the Lieb???Oxford bound in a systematic way, Molecular Physics, vol.114, issue.7-8, p.1076, 2016. ,
Strictly correlated uniform electron droplets, Physical Review B, vol.83, issue.19, p.195111, 2011. ,
DOI : 10.1103/PhysRevB.83.195111
Electron avoidance: A nonlocal radius for strong correlation, Physical Review A, vol.90, issue.5, p.52512, 2014. ,
DOI : 10.1103/PhysRevA.90.052512
Construction of exchange-correlation functionals through interpolation between the non-interacting and the strong-correlation limit, The Journal of Chemical Physics, vol.143, issue.12, p.124103, 2015. ,
DOI : 10.1063/1.4931160
The shell model for the exchange-correlation hole in the strong-correlation limit, The Journal of Chemical Physics, vol.145, issue.12, p.124104, 2016. ,
DOI : 10.1063/1.4962738
Multimarginal optimal transport and potential optimization problems for Schrödinger operators, 2016. ,
