Designing an Optimal Shape Warehouse
The paper addresses the topic of designing the shape of a warehouse and shows a comparison between a standard storage-handling system, which is designed taking into account the minimization of the handling planar path, and the one which is designed trying to minimizing the overall handling energy consumption. This comparison leads to a discussion on the opportunities which result from the construction of a shallow warehouse in term of building construction costs, layout management and storage surface efficiency. This paper is the first step in the analysis of a more comprehensive research about the life cycle assessment of a warehouse, the manpower utilization and the balanced equilibrium between handling energy requirement and performances of most used handling systems.
Informatique [cs]
