Profiling Context Awareness in Mobile and Cloud Based Engineering Asset Management - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Petros Pistofidis
  • Fonction : Auteur
  • PersonId : 1001948
Christos Emmanouilidis
  • Fonction : Auteur
  • PersonId : 1001949
This paper presents an analysis of the potential and a methodology for handling context events and adaptations in maintenance services. A significant number of industrial IT systems employ data models and service frameworks whose design specifications where drafted on the basis of functional requirements for non context-aware systems. Such systems were modular in nature but little care was taken for providing data fusion in a context-aware manner. Though system intelligence might have been a feature for a subset of such systems, two major requirements kept implementations away from wider adoption: (i) refactoring and reengineering of the system’s base services (ii) customising and modifying the structure of a data model tightly connected with inter-process organisation. This paper discusses a methodology for injecting industrial asset management systems with modelling semantics and software mechanisms that enable context awareness via portable clients and application-agnostic data fusion services.
978-3-642-40361-3_3_Chapter.pdf (877.05 Ko) Télécharger le fichier
hal-01470635 , version 1 (17-02-2017)
Paternité
Petros Pistofidis, Christos Emmanouilidis. Profiling Context Awareness in Mobile and Cloud Based Engineering Asset Management. 19th Advances in Production Management Systems (APMS), Sep 2012, Rhodes, Greece. pp.17-24, ⟨10.1007/978-3-642-40361-3_3⟩. ⟨hal-01470635⟩
125 Consultations
105 Téléchargements
