Proposing an Environmental Excellence Self-Assessment Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Peter Meulengracht Jensen
  • Fonction : Auteur
  • PersonId : 1001973
John Johansen
  • Fonction : Auteur
  • PersonId : 1001974
Brian Vejrum Waehrens
  • Fonction : Auteur
  • PersonId : 1001975
Md. Shewan-Ul-Alam
  • Fonction : Auteur
  • PersonId : 1001976
This paper presents an Environmental Excellence Self-Assessment (EEA) model based on the structure of the European Foundation of Quality Management Business Excellence Framework. Four theoretical scenarios for deploying the model are presented as well as managerial implications, suggesting that the EEA model can be used in global organizations to differentiate environmental efforts depending on the maturity stage of the individual sites. Furthermore, the model can be used to support the decision-making process regarding when organizations should embark on more complex environmental efforts to continue to realize excellent environmental results. Finally, a development trajectory for environmental excellence is presented.
978-3-642-40361-3_65_Chapter.pdf (294.33 Ko) Télécharger le fichier
hal-01470661 , version 1 (17-02-2017)
Paternité
Peter Meulengracht Jensen, John Johansen, Brian Vejrum Waehrens, Md. Shewan-Ul-Alam. Proposing an Environmental Excellence Self-Assessment Model. 19th Advances in Production Management Systems (APMS), Sep 2012, Rhodes, Greece. pp.511-518, ⟨10.1007/978-3-642-40361-3_65⟩. ⟨hal-01470661⟩
64 Consultations
102 Téléchargements
