Reports
Optimizing Affine Control with Semantic Factorizations
Abstract : Hardware accelerators generated by polyhedral synthesis make an extensive use of affine expressions (affine functions and convex polyhedra) in control and steering logic. Since the control is pipelined, these affine objects must to be evaluated at the same time for different values, which forbids aggressive reuse of operators. In this report, we propose a method to factorize a collection of affine expressions without preventing pipelining. Our key contributions are (i) to use semantic factorizations exploiting arithmetic properties of addition and multiplication and (ii) to rely on a cost function whose minimization ensures a correct usage of FPGA resources. Our algorithm is totally parametrized by the cost function, which can be customized to fit a target FPGA. Experimental results on a large pool of applications show a significant improvement compared to traditionnal common subexpression factorization. As a bonus, the optimization gain is statistically more regular compared to common subexpression elimination.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/hal-01470873
Contributor : Christophe Alias Connect in order to contact the contributor
Submitted on : Friday, February 17, 2017 - 7:45:51 PM
Last modification on : Friday, September 10, 2021 - 2:34:06 PM
Long-term archiving on: : Thursday, May 18, 2017 - 3:23:54 PM
File
RR-9034.pdf
Identifiers
  • HAL Id : hal-01470873, version 1
Citation
Christophe Alias, Alexandru Plesco. Optimizing Affine Control with Semantic Factorizations. [Research Report] RR-9034, INRIA Grenoble - Rhone-Alpes. 2017, pp.24. ⟨hal-01470873v1⟩
Share
Metrics
Record views
86
Files downloads
21
