Kinetic formulation of a $2 \times 2$ hyperbolic system arising in gas chromatography - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Kinetic and Related Models Année : 2020
The PSA system commonly used in the context of gas-solid chromatography is reformulated as a single kinetic equation using an additional kinetic variable. A kinetic numerical scheme is built from this new formulation and its behavior is tested on solving the Riemann problem in different configurations leading to single or composite waves.
BGJ3_HAL.pdf (449.16 Ko) Télécharger le fichier
hal-01471783 , version 1 (20-02-2017)
Christian Bourdarias, Marguerite Gisclon, Stéphane Junca. Kinetic formulation of a $2 \times 2$ hyperbolic system arising in gas chromatography. Kinetic and Related Models , 2020, 13 (5), pp.869-888. ⟨10.3934/krm.2020030⟩. ⟨hal-01471783⟩
330 Consultations
137 Téléchargements
