Agent Based Resources Allocation in Job Shop with Re-entrant Features: A Benchmarking Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Matteo Mario Savino
  • Fonction : Auteur
  • PersonId : 861268
Antonio Mazza
  • Fonction : Auteur
  • PersonId : 953967
Job shop production can be characterized by some unplanned event like re-entrant jobs at a certain stage of the production process. In this case a dynamic allocation management of the resources involved (machines, transporters, etc) can be key factor of success in optimizing some production parameter. The present work studies a multiple objective job shop in which the constraint that a workpiece visits a machine only once is relaxed. The production shop floor has been structured with a Multi Agent System (MAS) able to front dynamically these type of events. A benchmarking analysis is provided to compare the solutions found with other two main dynamic MAS-based systems present in literature.
978-3-642-40352-1_44_Chapter.pdf (151.83 Ko) Télécharger le fichier
hal-01472262 , version 1 (20-02-2017)
Paternité
Matteo Mario Savino, Antonio Mazza. Agent Based Resources Allocation in Job Shop with Re-entrant Features: A Benchmarking Analysis. 19th Advances in Production Management Systems (APMS), Sep 2012, Rhodes, Greece. pp.350-358, ⟨10.1007/978-3-642-40352-1_44⟩. ⟨hal-01472262⟩
80 Consultations
90 Téléchargements
