The assembly line balancing problem, Journal of Industrial Engineering, vol.6, pp.18-25, 1955. ,
A Survey of Exact Algorithms for the Simple Assembly Line Balancing Problem, Management Science, vol.32, issue.8, pp.909-932, 1986. ,
DOI : 10.1287/mnsc.32.8.909
A survey on problems and methods in generalized assembly line balancing, European Journal of Operational Research, vol.168, issue.3, pp.694-715, 2006. ,
DOI : 10.1016/j.ejor.2004.07.023
Absalom: Balancing assembly lines with assignment restrictions, European Journal of Operational Research, vol.200, issue.3, pp.688-701, 2010. ,
DOI : 10.1016/j.ejor.2009.01.049
URL : http://www.db-thueringen.de/servlets/DerivateServlet/Derivate-20979/2008-2.pdf
Reduction approaches for a generalized line balancing problem, Computers & Operations Research, vol.39, issue.10, pp.2337-2345, 2012. ,
DOI : 10.1016/j.cor.2011.11.022
Multiobjective constructive heuristics for the 1/3 variant of the time and space assembly line balancing problem: ACO and random greedy search, Information Sciences, vol.180, issue.18, pp.3465-3487, 2010. ,
DOI : 10.1016/j.ins.2010.05.033
Including different kinds of preferences in a multiobjective and algorithm for time and space assembly line balancing on different Nissan scenarios, Expert Systems with Applications, vol.381, pp.709-720, 2011. ,
RULA: a survey method for the investigation of work-related upper limb disorders, Applied Ergonomics, vol.24, issue.2, pp.91-99, 1993. ,
DOI : 10.1016/0003-6870(93)90080-S
Risk Assessment and Management of Repetitive Movements and Exertions of Upper LimbsJob Analysis, Ocra Risk Indices, Prevention Strategies and Design Principles, 2002. ,
Accuracy of measurements for the revised NIOSH lifting equation, Applied Ergonomics, vol.29, issue.6, pp.433-438, 1997. ,
DOI : 10.1016/S0003-6870(98)00015-5
Incorporating ergonomic risks into assembly line balancing, European Journal of Operational Research, vol.212, issue.2, pp.277-286, 2011. ,
DOI : 10.1016/j.ejor.2011.01.056
