Success Factors for PDCA as Continuous Improvement Method in Product Development - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In order to maintain sustainability in an ever changing environment, where customer requirements contains a yearly price reduction over the life cycle of a product, decreased time for development of new products and increased product quality, there is an increased need for focus on continuous improvements. A well-known improvement method is the PDCA (Plan-Do-Check-Act), which many companies have succeeded in implementing in the manufacturing department. Not so common, is the use of this method for the development process. The aim of this article is to present success factors which must be in place to succeed in using the specified method, and thereby the desired improvement during continuous improvement initiatives within product development. Management commitment is ranked as most important followed by knowledge about how to use the method, when to apply PDCA, efficient performance and use of internal marketing activities to focusing on the topic.
978-3-642-40352-1_81_Chapter.pdf (244.79 Ko) Télécharger le fichier
hal-01472304 , version 1 (20-02-2017)
Paternité
Eirin Lodgaard, Inger Gamme, Knut Einar Aasland. Success Factors for PDCA as Continuous Improvement Method in Product Development. 19th Advances in Production Management Systems (APMS), Sep 2012, Rhodes, Greece. pp.645-652, ⟨10.1007/978-3-642-40352-1_81⟩. ⟨hal-01472304⟩
158 Consultations
1549 Téléchargements
