Behavioural Evaluation of Reputation-Based Trust Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In the field of trust and reputation systems research, there is a need for common and more mature evaluation metrics for the purpose of producing meaningful comparisons of system proposals. In the state of the art, evaluations are based on simulated comparisons of how quickly negative reputation reports spread in the network or which decision policy gains more points against others in a specific gamelike setting, for example. We propose a next step in identifying criteria for a maturity model on the behavioural analysis of reputation-based trust systems.
978-3-642-36796-0_14_Chapter.pdf (213.82 Ko) Télécharger le fichier
hal-01474208 , version 1 (22-02-2017)
Paternité
Sini Ruohomaa, Lea Kutvonen. Behavioural Evaluation of Reputation-Based Trust Systems. 5th International Working Conference on Enterprise Interoperability (IWEI), Mar 2013, Enschede, Netherlands. pp.158-171, ⟨10.1007/978-3-642-36796-0_14⟩. ⟨hal-01474208⟩
73 Consultations
378 Téléchargements
