Abstract : Many EA groups battle to establish an overall programme plan in a way that is integrated, achievable and understandable to the stakeholder and sponsor community as well as the downstream implementation groups, including: IT, Process Management, Human Resources and Product Management. This paper presents an approach that achieves these objectives in a simple way. The approach is currently being implemented in a fairly new enterprise architecture function within an aggressively expanding Telco with promising results. The problem is introduced and a solution including meta model and visual representations is discussed. Early findings are made to the effect that the technique is simple to apply as well as being effective in establishing shared understanding between the EA function, project sponsors, project stakeholders and IT personnel. The technique is explicated with an example that should make it easy for others to replicate in their own setting.
Type de document :
Communication dans un congrès
Wil Aalst; John Mylopoulos; Michael Rosemann; Michael J. Shaw; Clemens Szyperski; Janis Grabis; Marite Kirikova; Jelena Zdravkovic; Janis Stirna. 6th The Practice of Entrprise Modeling (PoEM), Nov 2013, Riga, Latvia. Springer, Lecture Notes in Business Information Processing, LNBIP-165, pp.266-276, 2013, The Practice of Enterprise Modeling. 〈10.1007/978-3-642-41641-5_19〉
https://hal.inria.fr/hal-01474783
Contributeur : Hal Ifip
Soumis le : jeudi 23 février 2017 - 10:47:21
Dernière modification le : jeudi 23 février 2017 - 10:54:54
Document(s) archivé(s) le : mercredi 24 mai 2017 - 12:57:58
Graham Mcleod. A Business and Solution Building Block Approach to EA Project Planning. Wil Aalst; John Mylopoulos; Michael Rosemann; Michael J. Shaw; Clemens Szyperski; Janis Grabis; Marite Kirikova; Jelena Zdravkovic; Janis Stirna. 6th The Practice of Entrprise Modeling (PoEM), Nov 2013, Riga, Latvia. Springer, Lecture Notes in Business Information Processing, LNBIP-165, pp.266-276, 2013, The Practice of Enterprise Modeling. 〈10.1007/978-3-642-41641-5_19〉. 〈hal-01474783〉
