Visualizing and Measuring Enterprise Architecture: An Exploratory BioPharma Case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Carliss Baldwin
  • Fonction : Auteur
  • PersonId : 1002479
Alan Maccormack
  • Fonction : Auteur
  • PersonId : 1002480
David Dreyfus
  • Fonction : Auteur
  • PersonId : 1002481
We test a method that was designed and used previously to reveal the hidden internal architectural structure of software systems. The focus of this paper is to test if it can also uncover new facts about the components and their relationships in an enterprise architecture, i.e., if the method can reveal the hidden external structure between architectural components. Our test uses data from a biopharmaceutical company. In total, we analyzed 407 components and 1,157 dependencies. Results show that the enterprise structure can be classified as a core-periphery architecture with a propagation cost of 23%, core size of 32%, and architecture flow through of 67%. We also found that business components can be classified as control elements, infrastructure components as shared, and software applications as belonging to the core. These findings suggest that the method could be effective in uncovering the hidden structure of an enterprise architecture.
978-3-642-41641-5_2_Chapter.pdf (2.64 Mo) Télécharger le fichier
hal-01474793 , version 1 (23-02-2017)
Paternité
Robert Lagerström, Carliss Baldwin, Alan Maccormack, David Dreyfus. Visualizing and Measuring Enterprise Architecture: An Exploratory BioPharma Case. 6th The Practice of Entrprise Modeling (PoEM), Nov 2013, Riga, Latvia. pp.9-23, ⟨10.1007/978-3-642-41641-5_2⟩. ⟨hal-01474793⟩
590 Consultations
199 Téléchargements
