Numerical and experimental investigation of mucociliary clearance breakdown in cystic fibrosis
Abstract : The human tracheobronchial tree surface is covered with mucus. A healthy mucus is an heterogeneous material flowing toward the esophagus and a major defense actor against local pathogen proliferation and pollutant deposition. An alteration of mucus or its environment such as in cystic fibrosis dramatically impacts the mucociliary clearance. In the present study, we investigate the mechanical organization and the physics of such mucus in human lungs by means of a joint experimental and numerical work. In particular, we focus on the influence of the shear-thinning mucus mobilized by a ciliated epithelium for mucociliary clearance. The proposed robust numerical method is able to manage variations of more than 5 orders of magnitude in the shear rate and viscosity. It leads to a cartography that allows to discuss major issues on defective mucociliary clearance in cystic fibrosis. Furthermore, the computational rheological analysis based on measurements shows that cystic fibrosis shear-thinning mucus tends to aggregate in regions of lower clearance. Yet, a rarefaction of periciliary fluid has a greater impact than the mucus shear-thinning effects.
Type de document :
Article dans une revue
Journal of Biomechanics, Elsevier, 2017, pp.8. 〈10.1016/j.jbiomech.2016.12.026〉
Liste complète des métadonnées
https://hal.inria.fr/hal-01476172
Contributeur : Marc Thiriet <>
Soumis le : vendredi 24 février 2017 - 16:03:09
Dernière modification le : vendredi 4 janvier 2019 - 17:32:32
Document(s) archivé(s) le : jeudi 25 mai 2017 - 13:42:43
Fichier
36R1-RC-DAA-MME-MT-PP.pdf
Fichiers produits par l'(les) auteur(s)
Citation
Robin Chatelin, Dominique Anne-Archard, Marlene Murris-Espin, Marc Thiriet, Philippe Poncet. Numerical and experimental investigation of mucociliary clearance breakdown in cystic fibrosis. Journal of Biomechanics, Elsevier, 2017, pp.8. 〈10.1016/j.jbiomech.2016.12.026〉. 〈hal-01476172〉
Métriques
Consultations de la notice
333
Téléchargements de fichiers
70
