UVHM: Model Checking Based Formal Analysis Scheme for Hypervisors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Yuchao She
  • Fonction : Auteur
  • PersonId : 1003079
Hui Li
  • Fonction : Auteur
Hui Zhu
  • Fonction : Auteur
Hypervisors act a central role in virtualization for cloud computing. However, current security solutions, such as installing IDS model on hypervisors to detect known and unknown attacks, can not be applied well to the virtualized environments. Whats more, people have not raised enough concern about vulnerabilities of hypervisors themselves. Existing works mainly focusing on hypervisors’ code analysis can only verify the correctness, rather than security, or only be suitable for open-source hypervisors. In this paper, we design a binary analysis tool using formal methods to discover vulnerabilities of hypervisors. In the scheme, Z notation, VDM, B, Object-Z or CSP formalism can be utilized as suitable modeling and specification languages. Our proposal sequently follows the process of disassembly, modeling, specification, and verification. Finally, the effectiveness of the method is demonstrated by detecting the vulnerability of Xen-3.3.0 in which a bug is added.
978-3-642-36818-9_31_Chapter.pdf (430.42 Ko) Télécharger le fichier
hal-01480185 , version 1 (01-03-2017)
Paternité
Yuchao She, Hui Li, Hui Zhu. UVHM: Model Checking Based Formal Analysis Scheme for Hypervisors. 1st International Conference on Information and Communication Technology (ICT-EurAsia), Mar 2013, Yogyakarta, Indonesia. pp.300-305, ⟨10.1007/978-3-642-36818-9_31⟩. ⟨hal-01480185⟩
113 Consultations
99 Téléchargements
