Abstract : In this paper, we propose a novel block cipher mode of operation (BCMO for short), named Output Protection Chain (OPC for short), which as a symmetric encryption structure is different from other existing BCMOs in that it employs two keys, rather than one key, to protect the output of the mode. The security threats of chosen-plaintext attacks on three existing common BCMOs, including the Cipher Feedback mode (CFB), the Output Feedback mode (OFB), and the Counter mode (CTR), are also analyzed. After that, we explain why the OPC mode (or simply the OPC) can effectively avoid chosen-plaintext attacks, and why its security level is higher than those of CFB, OFB, and CTR.
https://hal.inria.fr/hal-01480198 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Wednesday, March 1, 2017 - 11:05:49 AM Last modification on : Thursday, March 2, 2017 - 1:04:26 AM Long-term archiving on: : Tuesday, May 30, 2017 - 2:57:57 PM
Yi-Li Huang, Fang-Yie Leu, Jung-Chun Liu, Jing-Hao Yang. A Block Cipher Mode of Operation with Two Keys. 1st International Conference on Information and Communication Technology (ICT-EurAsia), Mar 2013, Yogyakarta, Indonesia. pp.392-398, ⟨10.1007/978-3-642-36818-9_43⟩. ⟨hal-01480198⟩
