An Extended Multi-secret Images Sharing Scheme Based on Boolean Operation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Huan Wang
  • Fonction : Auteur
  • PersonId : 1003121
Mingxing He
  • Fonction : Auteur
  • PersonId : 1003122
Xiao Li
  • Fonction : Auteur
  • PersonId : 1003123
An extended multi-secret images scheme based on Boolean operation is proposed, which is used to encrypt secret images with different dimensions to generate share images with the same dimension. The proposed scheme can deal with grayscale, color, and the mixed condition of grayscale and color images. Furthermore, an example is discussed and a tool is developed to verify the proposed scheme.
978-3-642-36818-9_59_Chapter.pdf (345.99 Ko) Télécharger le fichier
hal-01480211 , version 1 (01-03-2017)
Paternité
Huan Wang, Mingxing He, Xiao Li. An Extended Multi-secret Images Sharing Scheme Based on Boolean Operation. 1st International Conference on Information and Communication Technology (ICT-EurAsia), Mar 2013, Yogyakarta, Indonesia. pp.513-518, ⟨10.1007/978-3-642-36818-9_59⟩. ⟨hal-01480211⟩
50 Consultations
75 Téléchargements
