New interface
Conference papers
Minimal Noise Variance Decoder for Uncoordinated Multiple Access in VLC
Abstract : In a visible light communications system (VLC), light sources are responsible for both illumination, communications and positioning. These light sources inevitably interfere each others at the receiver. To retain the appealing advantage that VLC systems can reuse existing lighting infrastructure, using an extra network to control or synchronize the light sources should be avoided. This paper proposes an uncoordinated multiple access scheme for VLC systems with positioning capability. The proposed scheme does not require a central unit to coordinate the transmission of the transmitters. Transmitters can be asynchronous with one another and with the receiver. Each transmitter is allocated a unique codeword with L chips for a system with up to (L-1)/2 transmitters where L is prime. Due to the linear growth in complexity with respect to number of transmitters, our proposed scheme is feasible for systems with large numbers of transmitters. Our novel decoder can minimize the effect of additive Gaussian noise at the receiver side. Simulation results show that the proposed decoder outperforms zero-forcing decoder.
Document type :
Conference papers
Complete list of metadata
Cited literature [13 references]  Display  Hide  Download
https://hal.inria.fr/hal-01480640
Contributor : Chung Shue Chen Connect in order to contact the contributor
Submitted on : Wednesday, March 1, 2017 - 4:16:53 PM
Last modification on : Saturday, November 19, 2022 - 4:06:31 AM
Long-term archiving on: : Tuesday, May 30, 2017 - 5:41:01 PM
File
VTC_20170228_2.pdf
Identifiers
  • HAL Id : hal-01480640, version 1
Citation
Abdullah A Saed, Siu-Wai Ho, Jean-Marie Gorce, Chung Shue Chen. Minimal Noise Variance Decoder for Uncoordinated Multiple Access in VLC. IEEE Vehicular Technology Conference (VTC-Spring), Jun 2017, Sydney, Australia. ⟨hal-01480640⟩
Share
Metrics
Record views
251
Files downloads
199
