Noun Phrase Syntax and Definiteness Marking: A new explanation for the morphology of Earlier Egyptian participles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2014
Elsa Oréal
  • Fonction : Auteur
  • PersonId : 854430
This paper proposes a new analysis of various morphological features characterizing different forms of the participle in Earlier Egyptian: graphemic endings and gemination. In both cases, the proposed explanation is based on the idea that participles may show nominal rather than verbal morphology. Syntactic and functional parameters are identified that may explain the hitherto neglected distribution of and endings, and gemination is shown to be better understood in relationship with discur- sive and referential properties of the participle itself that can be regarded as involving a form of define- teness marking rather than TAM values.
Linguistique
2014 Participles. pdf.pdf (446.72 Ko) Télécharger le fichier
hal-01481017 , version 1 (28-03-2023)
  • HAL Id : hal-01481017 , version 1
Elsa Oréal. Noun Phrase Syntax and Definiteness Marking: A new explanation for the morphology of Earlier Egyptian participles. Eitan Grossman; Stéphane Polis; Andréas Stauder; Jean Winand. On Forms and Functions : Studies in Ancient Egyptian Grammar, 15, Widmaier Verlag, pp.173-200., 2014, Lingua Aegyptia – Studia Monographica, 978-3-943955-15-6. ⟨hal-01481017⟩
Collections
CNRS INALCO LLACAN
91 Consultations
22 Téléchargements
