Towards a TTCN-3 Test System for Runtime Testing of Adaptable and Distributed Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Mariam Lahami
  • Fonction : Auteur
  • PersonId : 1001792
Fairouz Fakhfakh
  • Fonction : Auteur
  • PersonId : 1003395
Moez Krichen
Mohamed Jmaiel
  • Fonction : Auteur
  • PersonId : 856429
Today, adaptable and distributed component based systems need to be checked and validated in order to ensure their correctness and trustworthiness when dynamic changes occur. Traditional testing techniques can not be used since they are applied during the development phase. Therefore, runtime testing is emerging as a novel solution for the validation of highly dynamic systems at runtime. In this paper, we illustrate how a platform independent test system based on the TTCN-3 standard can be used to execute runtime tests. The proposed test system is called TT4RT: TTCN-3 test system for Runtime Testing. A case study in the telemedicine field is used as an illustration to show the relevance of the proposed test system.
978-3-642-34691-0_7_Chapter.pdf (544.17 Ko) Télécharger le fichier
hal-01482412 , version 1 (03-03-2017)
Paternité
Mariam Lahami, Fairouz Fakhfakh, Moez Krichen, Mohamed Jmaiel. Towards a TTCN-3 Test System for Runtime Testing of Adaptable and Distributed Systems. 24th International Conference on Testing Software and Systems (ICTSS), Nov 2012, Aalborg, Denmark. pp.71-86, ⟨10.1007/978-3-642-34691-0_7⟩. ⟨hal-01482412⟩
58 Consultations
98 Téléchargements
