Reducing verification effort in component-based software engineering through built-in testing, Information Systems Frontiers, vol.9, issue.2-3, pp.151-162, 2007. ,
DOI : 10.1007/s10796-007-9029-4
A Distributed Test Architecture for Adaptable and Distributed Real-Time Systems, Journées nationales IDM, 2011. ,
Resource-Aware Test Suite Optimization, 2009 Ninth International Conference on Quality Software, pp.341-346, 2009. ,
DOI : 10.1109/QSIC.2009.51
Ubiquitous RATs, Proceedings of the 6th international workshop on Software engineering and middleware , SEM '06, pp.55-62, 2006. ,
DOI : 10.1145/1210525.1210538
Distributed Load Tests with TTCN-3, TestCom 2006: Proceedings of International Conference for Testing of Communicating Systems, pp.18-24, 2006. ,
DOI : 10.1007/11754008_12
Experimenting with Dynamic Test Component Deployment in TTCN-3, 2007 3rd International Conference on Testbeds and Research Infrastructure for the Development of Networks and Communities, pp.1-8, 2007. ,
DOI : 10.1109/TRIDENTCOM.2007.4444687
Smartsockets, Proceedings of the 16th international symposium on High performance distributed computing , HPDC '07, pp.1-10, 2007. ,
DOI : 10.1145/1272366.1272368
Automating Integration Testing of Large-Scale Publish/Subscribe Systems, Principles and Applications of Distributed Event-Based Systems. IGI Global, pp.140-163, 2010. ,
DOI : 10.4018/978-1-60566-697-6.ch007
Testing Challenges of Maritime Safety and Security Systems-of-Systems, Testing: Academic & Industrial Conference, Practice and Research Techniques (taic part 2008), pp.35-39, 2008. ,
DOI : 10.1109/TAIC-PART.2008.14
Safe Runtime Validation of Behavioral Adaptations in Autonomic Software, Lecture Notes in Computer Science, vol.6906, pp.31-46, 2011. ,
DOI : 10.1007/978-3-642-23496-5_3
A context-aware orchestrating and choreographic test framework for service-oriented applications, 2009 31st International Conference on Software Engineering, Companion Volume, pp.371-374, 2009. ,
DOI : 10.1109/ICSE-COMPANION.2009.5071024
Towards context-aware testing for semantic interoperability on PvC environments, 2004 IEEE International Conference on Systems, Man and Cybernetics (IEEE Cat. No.04CH37583), pp.1136-1141, 2004. ,
DOI : 10.1109/ICSMC.2004.1399775
Dynamic Software Architecture Management for Collaborative Communicating Systems, 2011. ,
URL : https://hal.archives-ouvertes.fr/tel-00583926
(V3.1.1): Methods for Testing and Specification (MTS); The Testing and Test Control Notation version 3, Part, vol.201, issue.1, pp.873-874, 2005. ,
Java components with constraints and preferences in automatic administration of execution and placement, Eleventh Euromicro Conference on Parallel, Distributed and Network-Based Processing, 2003. Proceedings., pp.266-273, 2003. ,
DOI : 10.1109/EMPDP.2003.1183598
Sensor Assignment In Virtual Environments Using Constraint Programming, Applications and Innovations in Intelligent Systems XV: Proceedings of AI-2007, the Twenty-seventh SGAI International Conference on Innovative Techniques and Applications of Artificial Intelligence Winner of Best Poster Presentation, pp.333-338, 2007. ,
DOI : 10.1007/978-1-84800-086-5_27
Reconfiguration dynamique du placement dans les grilles de calculs dirigée par des objectifs, 6ì eme Conférence Francophone sur les Systèmes d'Exploitation (CFSE'06), 2008. ,
Choco: an Open Source Java Constraint Programming Library, CPAIOR'08 Workshop on Open-Source Software for Integer and Contraint Programming (OSSICP'08), pp.1-10, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00483090
A Hybrid Genetic Algorithm for the 0???1 Multiple Knapsack Problem, Artificial Neural Nets and Genetic Algorithms, vol.3, pp.251-255, 1998. ,
DOI : 10.1007/978-3-7091-6492-1_55
Parallel Genetic Algorithm Solving 0/1 Knapsack Problem Running on the GPU, 16th International Conference on Soft Computing MENDEL 2010, pp.64-70, 2010. ,
The Core Concept for the Multidimensional Knapsack Problem, Lecture Notes in Computer Science, vol.3906, pp.195-208, 2006. ,
DOI : 10.1007/11730095_17
URL : https://hal.archives-ouvertes.fr/hal-01299570
Solution of the zero-one multiple knapsack problem, European Journal of Operational Research, vol.4, issue.4, pp.276-283, 1980. ,
DOI : 10.1016/0377-2217(80)90112-5
Parameterized Approximation Scheme for the Multiple Knapsack Problem, Proceedings of the twentieth Annual ACM-SIAM Symposium on Discrete Algorithms. SODA '09, pp.665-674, 2009. ,
DOI : 10.1137/080731207
Multiple multidimensional knapsack problem and its applications in cognitive radio networks, MILCOM 2008, 2008 IEEE Military Communications Conference, pp.1-7, 2008. ,
DOI : 10.1109/MILCOM.2008.4753629
