Die Methode der finiten Elemente f??r elliptische Gleichungen mit diskontinuierlichen Koeffizienten, Computing, vol.19, issue.3, pp.207-213, 1970. ,
DOI : 10.1007/BF02248021
A finite element method for interface problems in domains with smooth boundaries and interfaces, Advances in Computational Mathematics, vol.58, issue.1, pp.109-138, 1996. ,
DOI : 10.1007/BF02127700
Abstract, Communications in Computational Physics, vol.39, issue.05, pp.1562-1587 ,
DOI : 10.1016/j.jcp.2006.02.014
Modeling Electroporation in a Single Cell. I. Effects of Field Strength and Rest Potential, Biophysical Journal, vol.77, issue.3, pp.1213-1224, 1999. ,
DOI : 10.1016/S0006-3495(99)76973-0
A Neumann-Neumann algorithm for a mortar discretization of elliptic problems with discontinuous coefficients, Numerische Mathematik, vol.65, issue.4, pp.645-656, 2005. ,
DOI : 10.1007/s00211-004-0573-2
The immersed finite volume element methods for the elliptic interface problems, Mathematics and Computers in Simulation, vol.50, issue.1-4, pp.1-463, 1999. ,
DOI : 10.1016/S0378-4754(99)00061-0
Modelling assemblies of biological cells exposed to electric fields, CCECE '97. Canadian Conference on Electrical and Computer Engineering. Engineering Innovation: Voyage of Discovery. Conference Proceedings, pp.1259-1271, 1998. ,
DOI : 10.1109/CCECE.1997.608312
A Non-oscillatory Eulerian Approach to Interfaces in Multimaterial Flows (the Ghost Fluid Method), Journal of Computational Physics, vol.152, issue.2, pp.457-492, 1999. ,
DOI : 10.1006/jcph.1999.6236
Quad trees a data structure for retrieval on composite keys, Acta Informatica, vol.4, issue.1, pp.1-9, 1974. ,
DOI : 10.1007/BF00288933
Dielectric properties of tissues and biological materials: a critical review, CRC in Biomedical Engineering, vol.17, issue.1, pp.25-104, 1989. ,
Time Courses of Mammalian Cell Electropermeabilization Observed by Millisecond Imaging of Membrane Property Changes during the Pulse, Biophysical Journal, vol.76, issue.4, pp.2158-2165, 1999. ,
DOI : 10.1016/S0006-3495(99)77370-4
Antitumor drug delivery in multicellular spheroids by electropermeabilization, Journal of Controlled Release, vol.167, issue.2, pp.138-147, 2013. ,
DOI : 10.1016/j.jconrel.2013.01.021
Immersed-Interface Finite-Element Methods for Elliptic Interface Problems with Nonhomogeneous Jump Conditions, SIAM Journal on Numerical Analysis, vol.46, issue.1, pp.472-495, 2008. ,
DOI : 10.1137/060666482
Solving elliptic problems with discontinuities on irregular domains ??? the Voronoi Interface Method, Journal of Computational Physics, vol.298, pp.747-765, 2015. ,
DOI : 10.1016/j.jcp.2015.06.026
A discontinuous Galerkin method for elliptic interface problems with application to electroporation, Communications in Numerical Methods in Engineering, vol.59, issue.10, pp.991-1008, 2009. ,
DOI : 10.1002/cnm.1132
Multicellular tumor spheroids: An underestimated tool is catching up again, Journal of Biotechnology, vol.148, issue.1, pp.3-15, 2010. ,
DOI : 10.1016/j.jbiotec.2010.01.012
A mortar element method for elliptic problems with discontinuous coefficients, IMA Journal of Numerical Analysis, vol.22, issue.4, pp.549-576, 2001. ,
DOI : 10.1093/imanum/22.4.549
???Classical??? Electropermeabilization Modeling at the Cell Scale, Journal of Mathematical Biology, vol.1724, issue.4, pp.235-265, 2014. ,
DOI : 10.1007/s00285-012-0629-3
A second-order Cartesian method for the simulation of electropermeabilization cell models, Journal of Computational Physics, vol.292, pp.114-140, 2015. ,
DOI : 10.1016/j.jcp.2015.03.028
Conducting and permeable states of cell membrane submitted to high voltage pulses: Mathematical and numerical studies validated by the experiments, Journal of Theoretical Biology, vol.360, pp.83-94, 2014. ,
DOI : 10.1016/j.jtbi.2014.06.027
The Immersed Interface Method for Elliptic Equations with Discontinuous Coefficients and Singular Sources, SIAM Journal on Numerical Analysis, vol.31, issue.4, pp.1019-1044, 1994. ,
DOI : 10.1137/0731054
New Cartesian grid methods for interface problems using the finite element formulation, Numerische Mathematik, vol.96, issue.1, pp.61-98, 2003. ,
DOI : 10.1007/s00211-003-0473-x
A Boundary Condition Capturing Method for Poisson's Equation on Irregular Domains, Journal of Computational Physics, vol.160, issue.1, p.151, 2000. ,
DOI : 10.1006/jcph.2000.6444
Convergence of the ghost-fluid method for elliptic equations with interfaces, Math. Comp, vol.72, pp.1731-1746, 2003. ,
Geometric modeling using octree encoding, Computer Graphics and Image Processing, vol.19, issue.2, pp.129-147, 1982. ,
DOI : 10.1016/0146-664X(82)90104-6
Local level set method in high dimension and codimension, Journal of Computational Physics, vol.200, issue.1, pp.368-382, 2004. ,
DOI : 10.1016/j.jcp.2004.04.019
Therapeutic perspectives of in vivo cell electropermeabilization, Bioelectrochemistry, vol.53, issue.1, pp.1-10, 2001. ,
DOI : 10.1016/S0302-4598(00)00112-4
A second-order discretization of the nonlinear Poisson???Boltzmann equation over irregular geometries using non-graded adaptive Cartesian grids, Journal of Computational Physics, vol.230, issue.5, pp.2125-2140, 2010. ,
DOI : 10.1016/j.jcp.2010.12.008
Fronts propagating with curvature-dependent speed: Algorithms based on Hamilton-Jacobi formulations, Journal of Computational Physics, vol.79, issue.1, pp.12-49, 1988. ,
DOI : 10.1016/0021-9991(88)90002-2
Different Approaches Used in Modeling of Cell Membrane Electroporation, Handbook on Electroporation ,
DOI : 10.1007/978-3-319-26779-1_3-1
URL : https://hal.archives-ouvertes.fr/hal-01483487
Electropermeabilization of dense cell suspensions, European Biophysics Journal, vol.41, issue.3, pp.173-185, 2007. ,
DOI : 10.1007/s00249-006-0115-1
Tree Methods for Moving Interfaces, Journal of Computational Physics, vol.151, issue.2, pp.616-648, 1999. ,
DOI : 10.1006/jcph.1999.6205
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.34.3444
Electropermeabilization of the cell membrane, Electroporation Protocols. Preclinical and Clinical Gene Medicine, 2014. ,
Mechanisms of cell membrane electropermeabilization: A minireview of our present (lack of ?) knowledge, Biochimica et Biophysica Acta (BBA) - General Subjects, vol.1724, issue.3, pp.270-280, 2005. ,
DOI : 10.1016/j.bbagen.2005.05.006
The influence of skeletal muscle anisotropy on electroporation: in vivo study and numerical modeling, Medical & Biological Engineering & Computing, vol.48, issue.7, pp.637-648, 2010. ,
Membrane electroporation: The absolute rate equation and nanosecond time scale pore creation, Physical Review E, vol.74, issue.2, p.21904, 2006. ,
DOI : 10.1103/PhysRevE.74.021904
Chinese hamster ovary cells sensitivity to localized electrical stresses, Bioelectrochemistry and Bioenergetics, vol.48, issue.1, pp.17-25, 1999. ,
DOI : 10.1016/S0302-4598(98)00239-6
Electroporation of cells and tissues, IEEE Trans. on Plasma Sci, vol.28, 2000. ,
