Montgomery curves and their arithmetic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Cryptographic Engineering Année : 2017
Three decades ago, Montgomery introduced a new elliptic curve model for use in Lenstra's ECM factorization algorithm. Since then, his curves and the algorithms associated with them have become foundational in the implementation of elliptic curve cryptosystems. This article surveys the theory and cryptographic applications of Montgomery curves over non-binary finite fields, including Montgomery's x-only arithmetic and Ladder algorithm, x-only Diffie–Hellman, y-coordinate recovery, and 2-dimensional and Euclidean differential addition chains such as Montgomery's PRAC algorithm.
Monty_arxiv.pdf (283.47 Ko) Télécharger le fichier
hal-01483768 , version 1 (06-03-2017)
Craig Costello, Benjamin Smith. Montgomery curves and their arithmetic: The case of large characteristic fields. Journal of Cryptographic Engineering, 2017, Special issue on Montgomery arithmetic, ⟨10.1007/s13389-017-0157-6⟩. ⟨hal-01483768⟩
874 Consultations
1429 Téléchargements
