The effect of temperature rise of fuzzylogic-controlled braking resistors on transient stability, IEEE Transactions on Power Systems, vol.19, issue.2, pp.1085-1095, 2004. ,
Effect of Coordination of Optimal Reclosing and Fuzzy Controlled Braking Resistor on Transient Stability During Unsuccessful Reclosing, IEEE Transactions on Power Systems, vol.21, issue.3, pp.1321-1330, 2006. ,
DOI : 10.1109/TPWRS.2006.876670
Wide-Area Measurement-Based Stabilizing Control of Power System Considering Signal Transmission Delay, IEEE Transactions on Power Systems, vol.19, issue.4, pp.1971-1979, 2004. ,
DOI : 10.1109/TPWRS.2004.835669
Microtran Power System Analysis Corporation, 1992. ,
An Introduction to Fuzzy Control, 1993. ,
Cyber Security and Power System Communication—Essential Parts of a Smart Grid Infrastructure, IEEE Transactions on Power Delivery, vol.25, issue.3, pp.1501-1507, 2010. ,
DOI : 10.1109/TPWRD.2010.2046654
Communication challenges for the FREEDM System, 2009. ,
Actual operating experience of on-line transient stability control systems (TSC systems), 2000 IEEE Power Engineering Society Winter Meeting. Conference Proceedings (Cat. No.00CH37077), pp.84-89, 2000. ,
DOI : 10.1109/PESW.2000.849932
Study of Security Attributes of Smart Grid Systems ? Current Cyber Security Issues, 2009. ,
Development of transient stability control system (TSC system) based on on-line stability calculation, IEEE Transactions on Power Systems, vol.11, issue.3, pp.1463-1472, 1996. ,
DOI : 10.1109/59.535687
Modelling and Simulation for Performance Evaluation of IEC61850-Based Substation Communication Systems, IEEE Transactions on Power Delivery, vol.22, issue.3, pp.1482-1489, 2007. ,
DOI : 10.1109/TPWRD.2006.886788
Latency Viewed as a Stochastic Process and its Impact on Wide Area Power System Control Signals, IEEE Transactions on Power Systems, vol.23, issue.1, pp.84-91, 2008. ,
DOI : 10.1109/TPWRS.2007.913210
WACS-Wide-Area Stability and Voltage Control System: R&D and Online Demonstration, Proceedings of the IEEE, pp.892-906, 2005. ,
DOI : 10.1109/JPROC.2005.846338
A survey on the communication architectures in smart grid, Computer Networks, vol.55, issue.15, pp.3604-3629, 2011. ,
DOI : 10.1016/j.comnet.2011.07.010
An investigation of time transfer accuracies over a utility microwave communications channel, IEEE Transactions on Power Delivery, vol.8, issue.3, pp.993-999, 1993. ,
DOI : 10.1109/61.252627
Evaluation of Time Delay Effects to Wide-Area Power System Stabilizer Design, IEEE Transactions on Power Systems, vol.19, issue.4, pp.1935-1941, 2004. ,
DOI : 10.1109/TPWRS.2004.836272
Delay-Dependent Stability Analysis of the Power System With a Wide-Area Damping Controller Embedded, IEEE Transactions on Power Systems, vol.26, issue.1, pp.233-240, 2011. ,
DOI : 10.1109/TPWRS.2010.2093031
