Agent Interaction and State Determination in SCADA Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Defensive actions in critical infrastructure environments will increasingly require automated agents to manage the complex, dynamic interactions that occur between operators and malicious actors. Characterizing such agent behavior requires the ability to reason about distributed environments where the state of a channel or process depends on the actions of the opposing sides. This paper describes an extension to the Applied π-Calculus for modeling agent behavior in critical infrastructure environments. The utility of the extension is demonstrated via an agent-based attack and defense interaction scenario.
978-3-642-35764-0_8_Chapter.pdf (1.05 Mo) Télécharger le fichier
hal-01483823 , version 1 (06-03-2017)
Paternité
Thomas Mcevoy, Stephen Wolthusen. Agent Interaction and State Determination in SCADA Systems. 6th International Conference on Critical Infrastructure Protection (ICCIP), Mar 2012, Washington, DC, United States. pp.99-109, ⟨10.1007/978-3-642-35764-0_8⟩. ⟨hal-01483823⟩
55 Consultations
68 Téléchargements
