Abstract : We present a novel non-interactive (t,n)-incidence count estimation
for indicator vectors ensuring Differential
Privacy. Given one or two
differentially private indicator vectors, estimating the distinct count
of elements in each and their intersection cardinality
(equivalently, their inner product) have been studied in
the literature, along with other extensions for estimating the
cardinality set intersection in case the elements are hashed prior to
insertion. The core contribution
behind all these studies was to address the problem of estimating the
Hamming weight (the number of bits set to one) of a bit vector from its
differentially private version, and in the case of inner product and set
intersection, estimating the number of positions which are jointly set
to one in both bit vectors.
We develop the most general case of estimating the number of positions
which are set to one in exactly t out of n bit vectors (this quantity is denoted the (t,n)-incidence count), given
access only to the differentially private version of those bit
vectors. This means that if each bit vector belongs to a different
owner, each can locally sanitize their bit vector prior to sharing it,
hence the non-interactive nature of our algorithm.
Our main contribution is a novel algorithm that simultaneously
estimates the (t,n)-incidence counts for all t in {0,...,n}. We
provide upper and lower bounds to the estimation error.
Our lower bound is achieved by generalizing the limit of two-party
differential privacy into
n-party differential privacy, which is a contribution of independent
interest. In particular we prove a lower bound on the additive error
that must be incurred by any n-wise inner product of n mutually
differentially-private bit vectors.
Our results are very general and are not limited to differentially
private bit vectors. They should apply to a large class of sanitization
mechanism of bit vectors which depend on flipping the bits with a
constant probability.
Some potential applications for our technique include physical
mobility analytics, call-detail-record
analysis, and similarity metrics
computation.
