I)/(50 * Pi^3-30 * Pi^2-3 * Pi) Real part is 0; Going for a recursive call Newton polygon is [[0 1] [1 0]] xi is (see below) real part is non zero. We're done. It took 3.596 seconds References, Algorithms in Real Algebraic Geometry, 2006. ,
Differential-Difference Equations, The Rand Corporation, 1963. ,
Separating linear forms and Rational Univariate Representations of bivariate systems, Journal of Symbolic Computation, vol.68, pp.84-119, 2015. ,
DOI : 10.1016/j.jsc.2014.08.009
URL : https://hal.archives-ouvertes.fr/hal-00977671
Solving bivariate systems using Rational Univariate Representations, Journal of Complexity, vol.37, pp.34-75, 2016. ,
DOI : 10.1016/j.jco.2016.07.002
URL : https://hal.archives-ouvertes.fr/hal-01342211
Computer algebra methods for the stability analysis of differential systems with commensurate time-delays, Proceedings of the 13th IFAC Workshop on Time Delay Systems, pp.22-24, 2016. ,
DOI : 10.1016/j.ifacol.2016.07.528
URL : https://hal.archives-ouvertes.fr/hal-01415282
Polynomial real root isolation using Descarte's rule of signs, Proceedings of the third ACM symposium on Symbolic and algebraic computation , SYMSAC '76, pp.272-275, 1976. ,
DOI : 10.1145/800205.806346
Ideals, Varieties, and Algorithms, ser. Undergraduate Texts in Mathematics, 2007. ,
On the computation of the topology of a non-reduced implicit space curve, Proceedings of the twenty-first international symposium on Symbolic and algebraic computation, ISSAC '08, pp.47-54, 2008. ,
DOI : 10.1145/1390768.1390778
Rational Puiseux expansions, Compositio Math, vol.70, issue.2, pp.119-154, 1989. ,
Theory of Functional Differential Equations, 1977. ,
DOI : 10.1007/978-1-4612-9892-2
Computing Real Roots of Real Polynomials ... and now For Real!, Proceedings of the ACM on International Symposium on Symbolic and Algebraic Computation, ISSAC '16, 2016. ,
DOI : 10.1145/2930889.2930937
URL : https://hal.archives-ouvertes.fr/hal-01363955
All Algebraic Functions Can Be Computed Fast, Journal of the ACM, vol.25, issue.2, pp.245-260, 1978. ,
DOI : 10.1145/322063.322068
URL : http://www.dtic.mil/cgi-bin/GetTRDoc?AD=ADA032345&Location=U2&doc=GetTRDoc.pdf
On Computing Puiseux Series for Multiple Imaginary Characteristic Roots of LTI Systems With Commensurate Delays, IEEE Transactions on Automatic Control, vol.58, issue.5, pp.1338-1343, 2013. ,
DOI : 10.1109/TAC.2012.2226102
URL : https://hal.archives-ouvertes.fr/hal-00935428
Analytic Curve Frequency-Sweeping Stability Tests for Systems with Commensurate Delays, 2015. ,
DOI : 10.1007/978-3-319-15717-7
URL : https://hal.archives-ouvertes.fr/hal-01284722
Characterizing invariance property of uniformly distributed delay systems ,
Time-Delay. Systems: Stability and Performance Criteria with Applications, 1992. ,
Delay Effects on Stability: A Robust Control Approach, ser. Lecture Notes in Control and Information Sciences, 2001. ,
An exact method for the stability analysis of time-delayed linear time-invariant (LTI) systems, IEEE Transactions on Automatic Control, vol.47, issue.5, pp.793-796, 2002. ,
DOI : 10.1109/TAC.2002.1000275
Computing monodromy groups defined by plane algebraic curves, Proceedings of the 2007 International Workshop on Symbolic-Numeric Computation, pp.36-45, 2007. ,
Calcul de développements de puiseux et application au calcul de groupe de monodromie d'une courbe algébrique plane, 2008. ,
Complexity bounds for the rational Newton-Puiseux algorithm over finite fields, Applicable Algebra in Engineering, Communication and Computing, vol.69, issue.1???2, pp.187-217, 2011. ,
DOI : 10.1007/s00200-011-0144-6
URL : https://hal.archives-ouvertes.fr/hal-00601438
A stability test for systems with delays, Proc. Joint Automatic Control Conf, 1980. ,
Solving Zero-Dimensional Systems Through the Rational Univariate Representation, Applicable Algebra in Engineering, Communication and Computing, vol.9, issue.5, pp.433-461, 1999. ,
DOI : 10.1007/s002000050114
URL : https://hal.archives-ouvertes.fr/inria-00073264
Efficient isolation of polynomial's real roots, Journal of Computational and Applied Mathematics, vol.162, issue.1, pp.33-50, 2003. ,
DOI : 10.1016/j.cam.2003.08.015
Algorithmes pour l'étude des solutions rélles des systèmes polynomiaux ,
RS: Real Roots isolation for algebraic systems with rational coefficients with a finite number of complex roots ,
Algebraic Curves, 1950. ,
Borne 40 avenue Halley -Bât A -Park Plaza 59650 Villeneuve d'Ascq Publisher Inria Domaine de Voluceau -Rocquencourt BP 105 -78153 Le Chesnay Cedex inria ,
