Economic Advantages by CAD/CAM Use in Compound with Production Data Organization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Arndt Richter
  • Fonction : Auteur
  • PersonId : 1003745
Current developments concerning the manufacturing industry cause also new and additional requirements for the use of CAD/CAM systems. It is represented that beside the technological further development especially the virtualization of the planning processes has significant influence. Furthermore the local technical consideration of the CAD/CAM process is not sufficient. The general organization in the factory has to be considered. The integrated consideration of the physical specification of the production means with the organization of the production resources ensures a long-term economic success for the CAD/CAM use. To realize this target the possibilities and advantages are described in this article.
978-3-642-41329-2_7_Chapter.pdf (387.25 Ko) Télécharger le fichier
hal-01485840 , version 1 (09-03-2017)
Paternité
Arndt Richter. Economic Advantages by CAD/CAM Use in Compound with Production Data Organization. 6th Programming Languages for Manufacturing (PROLAMAT), Oct 2013, Dresden, Germany. pp.53-60, ⟨10.1007/978-3-642-41329-2_7⟩. ⟨hal-01485840⟩
193 Consultations
96 Téléchargements
