Semantics of barriers in a non-strict, implicitlyparallel language, Proceedings of FPCA'95, pp.204-215, 1995. ,
May-happen-in-parallel analysis of X10 programs, Proceedings of the 12th ACM SIGPLAN symposium on Principles and practice of parallel programming , PPoPP '07, pp.183-193, 2007. ,
DOI : 10.1145/1229428.1229471
Loose synchronization for large-scale networked systems, Proceedings of ATEC'06, pp.28-28, 2006. ,
??S, Electronic Notes in Theoretical Computer Science, vol.16, issue.3, pp.265-290, 1998. ,
DOI : 10.1016/S1571-0661(04)00146-X
Barrier Synchronisation for occampi, Proceedings of PDPTA'05, pp.173-179, 2005. ,
Habanero-Java, Proceedings of the 9th International Conference on Principles and Practice of Programming in Java, PPPJ '11, pp.51-61, 2011. ,
DOI : 10.1145/2093157.2093165
X10: an object-oriented approach to non-uniform cluster computing, Proceedings of OOPSLA'05, pp.519-538, 2005. ,
Photoshop scalability: Keeping it simple, Queue, vol.8, pp.20-28, 2010. ,
OpenMP: an industry standard API for shared-memory programming, IEEE Computational Science and Engineering, vol.5, issue.1, pp.46-55, 1998. ,
DOI : 10.1109/99.660313
Featherweight X10: a core calculus for async-finish parallelism, Proceedings of PPoPP'10, pp.25-36, 2010. ,
The design of a task parallel library, Proceeding of OOPSLA'09, pp.227-242, 2009. ,
Types for X10 Clocks, Proceedings of PLACES'10, pp.111-129, 2011. ,
DOI : 10.4204/EPTCS.69.8
URL : http://doi.org/10.4204/eptcs.69.8
Intel Threading Building Blocks: Outfitting C++ for Multi-core Processor Parallelism. O'Reilly Media, 2007. ,
Concurrent Clustered Programming, Proceedings of CONCUR'05, pp.353-367, 2005. ,
DOI : 10.1007/11539452_28
Phaser beams: Integrating stream parallelism with task parallelism, X10 Workshop, 2011. ,
Phasers, Proceedings of the 22nd annual international conference on Supercomputing , ICS '08, pp.277-288, 2008. ,
DOI : 10.1145/1375527.1375568
Unifying Barrier and Point-to-Point Synchronization in OpenMP with Phasers, Proceeding of IWOMP'11, pp.122-137, 2011. ,
DOI : 10.1007/978-3-642-00722-4_5
Implementing irregular parallel algorithms with OpenMP, Proceedings of Euro-Par'06, pp.635-644, 2006. ,
Ad hoc synchronization considered harmful, Proceedings of OSDI'10, pp.1-8, 2010. ,
