New interface
Conference papers
Conjunctive Queries on Probabilistic Graphs: Combined Complexity
Abstract : Query evaluation over probabilistic databases is known to be intractable in many cases, even in data complexity, i.e., when the query is fixed. Although some restrictions of the queries [20] and instances [4] have been proposed to lower the complexity, these known tractable cases usually do not apply to combined complexity, i.e., when the query is not fixed. This leaves open the question of which query and instance languages ensure the tractability of probabilistic query evaluation in combined complexity. This paper proposes the first general study of the combined complexity of conjunctive query evaluation on probabilistic instances over binary signatures, which we can alternatively phrase as a probabilistic version of the graph homomor-phism problem, or of a constraint satisfaction problem (CSP) variant. We study the complexity of this problem depending on whether instances and queries can use features such as edge labels, disconnectedness, branching, and edges in both directions. We show that the complexity landscape is surprisingly rich, using a variety of technical tools: automata-based compilation to d-DNNF lineages as in [4], β-acyclic lin-eages using [11], the X-property for tractable CSP from [25], graded DAGs [28] and various coding techniques for hardness proofs.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-01486634
Contributor : Pierre Senellart Connect in order to contact the contributor
Submitted on : Friday, March 10, 2017 - 11:13:05 AM
Last modification on : Wednesday, June 8, 2022 - 12:50:06 PM
Long-term archiving on: : Sunday, June 11, 2017 - 2:20:17 PM
File
main.pdf
Identifiers
Citation
Antoine Amarilli, Mikaël Monet, Pierre Senellart. Conjunctive Queries on Probabilistic Graphs: Combined Complexity. Principles of Database Systems (PODS), May 2017, Chicago, United States. ⟨10.1145/3034786.3056121⟩. ⟨hal-01486634⟩
Share
Metrics
Record views
225
Files downloads
64
