Towards a Definition of Local Stationarity for Graph Signals
In this paper, we extend the recent definition of graph stationarity into a definition of local stationarity. Doing so, we present a metric to assess local stationarity using projections on localized atoms on the graph. Energy of these projections defines the local power spectrum of the signal. We use this local power spectrum to characterize local stationarity and identify sources of non-stationarity through differences of local power spectrum. Finally, we take advantage of the knowledge of the spectrum of the atoms to give a new power spectrum estimator.
icassp2017.pdf (584.67 Ko)
Télécharger le fichier
icassp2017_poster.pdf (686.04 Ko)
