A Framework for Robust Traffic Engineering Using Evolutionary Computation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In current network infrastructures, several management tasks often require significant human intervention and can be of high complexity, having to consider several inputs to attain efficient configurations. In this perspective, this work presents an optimization framework able to automatically provide network administrators with efficient and robust routing configurations. The proposed optimization tool resorts to techniques from the field of Evolutionary Computation, where Evolutionary Algorithms (EAs) are used as optimization engines to solve the envisaged NP-hard problems. The devised methods focus on versatile and resilient aware Traffic Engineering (TE) approaches, which are integrated into an autonomous optimization framework able to assist network administrators. Some examples of the supported TE optimization methods are presented, including preventive, reactive and multi-topology solutions, taking advantage of the EAs optimization capabilities.
978-3-642-38998-6_1_Chapter.pdf (654.99 Ko) Télécharger le fichier
hal-01489965 , version 1 (14-03-2017)
Paternité
Vitor Pereira, Miguel Rocha, Paulo Cortez, Miguel Rio, Pedro Sousa. A Framework for Robust Traffic Engineering Using Evolutionary Computation. 7th International Conference on Autonomous Infrastructure (AIMS), Jun 2013, Barcelona, Spain. pp.1-12, ⟨10.1007/978-3-642-38998-6_1⟩. ⟨hal-01489965⟩
70 Consultations
110 Téléchargements
