Complexity Dichotomies for the Minimum F-Overlay Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2013
For a (possibly infinite) fixed family of graphs F, we say that a graph G overlays F on a hypergraph H if V(H) is equal to V(G) and the subgraph of G induced by every hyperedge of H contains some member of F as a spanning subgraph. While it is easy to see that the complete graph on |V(H)| overlays F on a hypergraph H whenever the problem admits a solution, the Minimum F-Overlay problem asks for such a graph with the minimum number of edges. This problem allows to generalize some natural problems which may arise in practice. For instance, if the family F contains all connected graphs, then Minimum F-Overlay corresponds to the Minimum Connectivity Inference problem (also known as Subset Interconnection Design problem) introduced for the low-resolution reconstruction of macro-molecular assembly in structural biology, or for the design of networks. Our main contribution is a strong dichotomy result regarding the polynomial vs. NP-hard status with respect to the considered family F. Roughly speaking, we show that the easy cases one can think of (e.g. when edgeless graphs of the right sizes are in F, or if F contains only cliques) are the only families giving rise to a polynomial problem: all others are NP-complete. We then investigate the parameterized complexity of the problem and give similar sufficient conditions on F that give rise to W[1]-hard, W[2]-hard or FPT problems when the parameter is the size of the solution. This yields an FPT/W[1]-hard dichotomy for a relaxed problem, where every hyperedge of H must contain some member of F as a (non necessarily spanning) subgraph.
RR-9045.pdf (967.83 Ko) Télécharger le fichier
hal-01490535 , version 1 (15-03-2017)
Nathann Cohen, Frédéric Havet, Dorian Mazauric, Ignasi Sau, Rémi Watrigant. Complexity Dichotomies for the Minimum F-Overlay Problem. [Research Report] RR-9045, Inria Sophia Antipolis. 2013, pp.16. ⟨hal-01490535⟩
485 Consultations
127 Téléchargements
