Unlinkable Content Playbacks in a Multiparty DRM System
We present a solution to the problem of privacy invasion in a multiparty digital rights management scheme. (Roaming) users buy content licenses from a content provider and execute it at any nearby content distributor. Our approach, which does not need any trusted third party—in contrast to most related work on privacy-preserving DRM—is based on a re-encryption scheme that runs on any mobile Android device. Only a minor security-critical part needs to be performed on the device’s smartcard which could, for instance, be a SIM card.
Informatique [cs]
