New interface
Conference papers
Hardware Based Security Enhanced Direct Memory Access
Abstract : This paper presents an approach to prevent memory attacks enabled by DMA. DMA is a technique that is frequently used to release processors from simple memory transfers. DMA transfers are usually performed during idle times of the bus. A disadvantage of DMA transfers is that they are primarily unsupervised by anti malware agents. After the completion of a DMA activity the transfered data can be scanned for malicious codes. At this time the malicious structures are already in the memory and processor time is necessary to perform a malware scan. The approach presented in this paper enhances the DMA by a watchdog mechanisms that scans the data passing by and interrupts the processor after the detection of a malicious data or instruction sequence. Configurable hardware based on FPGAs is used to overcome the problem of frequently changing malware and malware signatures.
Complete list of metadata
https://hal.inria.fr/hal-01492816
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Monday, March 20, 2017 - 3:51:19 PM
Last modification on : Monday, March 20, 2017 - 3:55:41 PM
Long-term archiving on: : Wednesday, June 21, 2017 - 1:41:28 PM
File
978-3-642-40779-6_12_Chapter.p...
Identifiers
Citation
Marcel Eckert, Igor Podebrad, Bernd Klauer. Hardware Based Security Enhanced Direct Memory Access. 14th International Conference on Communications and Multimedia Security (CMS), Sep 2013, Magdeburg,, Germany. pp.145-151, ⟨10.1007/978-3-642-40779-6_12⟩. ⟨hal-01492816⟩
Share
Metrics
Record views
306
Files downloads
414
