Watermark Resynchronization: An Efficient Approach Based on Eulerian Tours around a Robust Skeleton - Archive ouverte HAL Access content directly
Conference Papers Year : 2013
(1) , (2) , (3) , (4) , (1, 5) , (1)
1
2
3
4
5
The existing block-based approaches, albeit successful in resisting frequency domain attacks, are sensitive to geometric distortions due to the lack of reference in repositioning the block grid. In this paper an RST-invariant block-based approach is proposed, aiming at protecting image objects. The term “image object” refers to semantically contiguous parts of images that have a specific contour boundary. The proposed approach is based on shape information, since the watermark is embedded in image blocks, the location and orientation of which are defined by Eulerian tours that are appropriately arranged in layers, around an object’s robust skeleton. Images from the Polymathic project are used to illustrate the technique.
978-3-642-40779-6_21_Chapter.pdf (411.9 Ko) Télécharger le fichier
Dates and versions
hal-01492826 , version 1 (20-03-2017)
Attribution - CC BY 4.0
Identifiers
Cite
Konstantinos Raftopoulos, Klimis Ntalianis, Paraskevi Tzouveli, Nicolas Tsapatsoulis, Aleatha Parker-Wood, et al.. Watermark Resynchronization: An Efficient Approach Based on Eulerian Tours around a Robust Skeleton. 14th International Conference on Communications and Multimedia Security (CMS), Sep 2013, Magdeburg,, Germany. pp.211-214, ⟨10.1007/978-3-642-40779-6_21⟩. ⟨hal-01492826⟩
69 View
68 Download
Share
